oxygen sensor replacement inspection
Old Jul 1, 2007 | 06:26 PM
Turbo_Mike's Avatar
Default oxygen sensor replacement inspection
I tried searching but couldnt find much because u cant search "o2"
Anyways, my friend has a 96 ex coupe and it failed nys emissions. Claimed the o2 was bad. I installed a new bosch o2 sensor for her ( the o2 on mani) and her code went away.
Question: Does the car have to be running or driving for a certain lenght of time for the ecu to "register" the o2 again before she can have it inspected tomorrow?
Old Jul 1, 2007 | 06:27 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: oxygen sensor replacement inspection (Turbo_Mike)
yes, don't know the parameters though
the o2 monitor should be the only one that has to pass now.
Old Jul 1, 2007 | 06:33 PM
Turbo_Mike's Avatar
Default Re: oxygen sensor replacement inspection (95DxSi-R2)
i let the car idle for about 5 minutes and nothing popped up... is it too early to celebrate ?
I thought i read somewhere you have to drive the car 50 miles...but idk if thats accurate
Old Jul 1, 2007 | 06:35 PM
97Ej6mike's Avatar
Once the CEL is cleared you are set to go, the ECU recognizes it right away, and nothing needs to be 'registered'.
Old Jul 1, 2007 | 06:36 PM
EM1_00Si's Avatar
The readiness monitors needs to be reset. I just did mine. I drove about 15 miles before having emissions inspected immediately after. The cars ecu must have a history of the car running correctly in order for it pass inspections, thats what the readiness monitors are for.
Old Jul 1, 2007 | 06:38 PM
Turbo_Mike's Avatar
Default Re: oxygen sensor replacement inspection (EM1_00Si)
what are the readiness monitors?
I just disconnected the battery for about 5 minutes, and only planned on driving it about 10 miles or so and prayin no cel pops back up
Nooget
13
Aug 14, 2010 08:12 PM
HONDA RR
Sep 16, 2005 03:53 PM
Shakes
Apr 28, 2004 08:45 PM
VSM EXtasy
Feb 3, 2003 08:58 AM
Rywire
Jan 4, 2003 09:53 PM
