Auto STD hub spline count....
Old Jul 1, 2007 | 03:57 PM
welfarepc's Avatar
Default Auto STD hub spline count....
The car is a 1990 Civic STD auto. It came with a D15B2. Doing auto to manual swap. I know on manual STD's the hubs have a different spline count then Si/DX. I also know the manual STD comes with a D15B1. I also know the auto axles from a DX with a D15b2 will work for the manual swap. What i dont know is how many splines Auto STD hubs/axles have.
Does anyone know?
Dan
Old Jul 1, 2007 | 04:10 PM
RCautoworks's Avatar
Default Re: Auto STD hub spline count.... (welfarepc)
From my saved files
The Si, DX, and LX all use the 26 spline outer joint. The HF and STD use the 23 spline outer joint.
Old Jul 1, 2007 | 04:16 PM
vdawg559's Avatar
how much u get that auto for?.. an i dont know sry... cant help u buddy
Old Jul 1, 2007 | 04:32 PM
welfarepc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">From my saved files
The Si, DX, and LX all use the 26 spline outer joint. The HF and STD use the 23 spline outer joint.</TD></TR></TABLE>
Hmm must be a weight reduction thing. thanks
car was $500, mint motor, no smoke, perfect 170 compression across, no rust MINT shell from soft climate. id be an idiot not to convert it.
gotta find dx hubs..
oh wait, i just scored and got an 88 Si CRX with a SOHC ZC, i can use those hubs! haha the car even comes with a garrett T3 with next to no shaft play! haha whole car for $425 (not running, but im a g like that)
Old Jul 8, 2007 | 12:43 PM
welfarepc's Avatar
so for anyone who does a manual swap on an Auto STD hatch with a D15B2, rest assured that your axles/hubs have 26 splines, so dont worry about replacing them and enjoy your new manual!
Dan
Old Jul 8, 2007 | 05:36 PM
Mista Bone's Avatar
D Tranny Guru
I believe the STD model never came with a slushbox.
To get a slushbox you had to buy a DX, hence why you have the larger DX/Si axles
Old Jul 8, 2007 | 08:13 PM
welfarepc's Avatar
you talking slushbox as in a d15b2? im gonna run the VIN tomorrow to check if the motor is stock
Old Jul 8, 2007 | 11:56 PM
Mista Bone's Avatar
D Tranny Guru
D15B2 = DX.
Seeing you a Canuck, (no offense) Honda of Canada changed the model designations.
Tonyl507
Aug 3, 2006 03:07 PM
SVOboy
Oct 8, 2005 11:36 AM
ne3ek
Jan 3, 2005 06:53 AM
gameeffect
19
Nov 2, 2004 10:11 PM
japrex
Oct 20, 2004 10:23 AM
