k20a or b18c
i jus wanna get a few opinions of wat would be better for my 92 civic si... i deciding whether to put a 98 spec b18c itr or putting a k20a in it and i wanna turbo it. i kno that i should change to lower compression pistion if i get the k20. and i kno somebody will tell me to put this in the forced introduction section and i already did... will the k20 be worth the extra money... or should i stick with the b series?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_Junkie »</TD></TR><TR><TD CLASS="quote">at the most $8500</TD></TR></TABLE>thats a hole lot of money for what youll get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight »</TD></TR><TR><TD CLASS="quote">thats a hole lot of money for what youll get</TD></TR></TABLE>
LOL not another k20 v h2b thread.
Last time I picked up a new troll and got a point docked for defending myself in an already off topic thread that should have been locked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 »</TD></TR><TR><TD CLASS="quote">ls1</TD></TR></TABLE>
lol
https://honda-tech.com/zerothread/2004368
lol
if you can do all the work yourself then do a k. you can do the entire thing for less than 8500 if you dn't have to pay for labor. if you need labor then do a b.
these are all iffy prices but yea
* K series motor/tranny/ECU 3500
* K series engine harness
* K series charging harness
* Hybrid Racing motor mounts 599
* Hybrid Racing conversion harness 350
* Hybrid Racing axles in appropriate stage 700
* Hybrid Racing clutch line 75
* Hybrid Racing radiator package 499
* B/D series coolant temp sensor and fan switch 26
* Hybrid Racing fuel rail 90
* Universal Fuel Pressure regulator 160
* Custom Fit Fuel lines 225
* OEM RSX shifter Box or Modified Accord shifter box 125
* RSX Shifter Cables
* Shifter linkage Clips
* Aftermarket intake
* Aftermarket Header 395
* Custom Mid Pipe
* Throttle cable for your application
* EP3 pulley and belt (if retaining AC and OEM belt) 92
* Karcepts Kit 150
* Kpro 1000
* Intake manifold heatshield 30
* Throttle body heatshield 20
* Clutch (exedy organic) 295
* Custom Mid Pipe
* Karcepts Kit 150
* Kpro 1000
This guy is 17. I know at 17 I wasn't capable of doing much more than swapping a D-series.
Much less all the fab work required to get a k in your car.
He's probably like me when I was 17, theoretically modding his car in his mind with monopoly money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>LoL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scorchin Civic »</TD></TR><TR><TD CLASS="quote">LoL</TD></TR></TABLE>
It's true, I'm almost 19 and finally I'll have the money do start ordering parts like Kirstie Ally at a BK.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8linek »</TD></TR><TR><TD CLASS="quote">doesnt this same thread get started every week?</TD></TR></TABLE>
Yeah, and a few people have reported it I think.
around my area k-series swaps are about 9g's...thats for everything drop ur car off wit 9g's in glove box comback u got a complete swap wit no problems.....basically ur payin so much b/c the motor is newer and its a pain in the *** to swap a k in a dc,ek,eg,& ef.....if have the cake by all means go for it....but u could go b18c build and turbo for around the same price and be faster then the stock K series that u would have for around the same price H-T correct me if im wrong.....But if ur like me and want to do something a little different or new then go K-series...its def ur ride!!!
K-series are nice, I'm sure I'll end up with one one day. but as of right now I can't justify spending the time sourcing out the parts or spending the money.
Not when I can get an h2b in my car for less than $4000.
the k20 is one of the worlds premier four cylinders for a reason.
I can't imagine doing an H2B swap. The K series has got to be easier than that. Im 17 and I have done 4 swaps and and a couple of clutch installs. As long as your smart about things and have tools you can do pretty much anything your self.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettoSi »</TD></TR><TR><TD CLASS="quote">I can't imagine doing an H2B swap. The K series has got to be easier than that. </TD></TR></TABLE>
You obviously haven't read much about h2b's.
once you grind the block and cut some of the framerail, it swaps in just like a b-series.
It's easy AS PIE in comparison to k swaps which involve hacking up the firewall, custom axles and halfshafts, mount brakets, etc.
It's easy AS PIE .</TD></TR></TABLE>
Lol ya that sounds like fun
It's really not bad. The total modification takes make 20 minutes for anyone who's skilled with a makita grinder.
</TD></TR></TABLE>It's really not bad. The total modification takes make 20 minutes for anyone who's skilled with a makita grinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettoSi »</TD></TR><TR><TD CLASS="quote">Or you could boost a D and be way faster.</TD></TR></TABLE>
LOL, you remind me of me two years ago.
