A/C belt alignment issues on LS/Vtec
Has anyone else run into this issue on their swap?
I have 92 EG with new LS/V installed on Friday and the a/c belt is a little bit off. Using the P7J bracket
Is this because I'm using my D compressor and is the B compressor a different length so it will line up correctly?
Thanks ahead of time for your help and input!
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">try using the p54 a/c bracket.</TD></TR></TABLE>
it might also be that you have an older ls crank pulley, im not sure how much of a difference it could be though
I had the same problem. I changed the tensioner and noticed that some had a thicker washer than others. You can also try using a washer to move the tensioner out a lil. good luck.
ekcoupe00
Sep 7, 2006 07:29 PM
BigBank420
Jul 9, 2002 07:10 AM
