NEED A CHANGE
go get a helms manual at autozone or something, they come in handy for simple tasks like this.
unplug both fans, unbolt both fans, remove both fans, drain coolant from the **** on lower passenger side of radiator, remove upper radiator hose, remove lower radiator hose, remove bolts/nuts on top of radiator, cant remeber if there are bolts on bottom of radiator or not, but if there are, remove those, now remove the radiator, installation is reverse of removal.
