prelude transmisions
Old Jul 1, 2007 | 11:19 AM
themurrell's Avatar
Default prelude transmisions
i have a f22 and my trany is grinding in 3rd so i want to get a new trany and i was wondering witch is better f22, h23 or h22 tranys? thank you
Old Jul 1, 2007 | 11:45 AM
dtec's Avatar
Default Re: prelude transmisions (themurrell)
The H22 tranny is the best for all motor I believe, since it has the shortest gear ratios of the trannys mentioned. Shorter gear ratios mean faster acceleration.
Old Jul 1, 2007 | 12:58 PM
InvaderTrax's Avatar
True, but lots of F22 people have better success with the H23 transmission because it's geared better towards their powerband
Old Jul 1, 2007 | 04:18 PM
Missing Gears's Avatar
Default Re: (InvaderTrax)
if you do alot of hwy driving and not so much racing at the track, youll be much happier w/ the h23 trans. but you could just rebuild your trans and save alot of $$
Old Jul 2, 2007 | 06:52 AM
themurrell's Avatar
how much would that cost compared to a new/ used trany
Old Jul 2, 2007 | 07:05 AM
piggydog's Avatar
try changing your tranny fluid first
Old Jul 2, 2007 | 12:06 PM
themurrell's Avatar
Default Re: prelude transmisions (piggydog)
they said its clear and full
Old Jul 5, 2007 | 06:06 PM
LudeNsoL's Avatar
yo i got that same problem, it happens when i shift into 3 fast
Old Jul 5, 2007 | 06:58 PM
ECX's Avatar
ECX
* B A N N E D *
Happens for me going into 2nd and 3rd quickly, I'm changing my transmission fluid and that should fix it, I'm hoping.
Old Jul 5, 2007 | 08:55 PM
themurrell's Avatar
Default Re: (ECX)
if i dubble clutch it just makes the noise so its not that big of a deal
Old Jul 6, 2007 | 09:06 AM
NirVTEC's Avatar
Default Re: (themurrell)
Trans rebuilds can be very expensive when done correctly......Not a wise idea to just replace what NEEDS replacing......When I priced out the rebuild I was over $800 in parts alone....
On the cheap.....find a used H23 trans! Bottom line is ANYTHING is better than a trans from an F.
Other option is a brand new trans from Honda to the tune of ~$2k.
Old Jul 6, 2007 | 09:16 AM
streetracer6rpt's Avatar
http://gearspeedinc.com/products.htm
Old Jul 6, 2007 | 11:21 AM
LudeNsoL's Avatar
Default Re: (ECX)
tell us if it worked and also wat kind of fluid is it, i want to get some
aaron_ex
Sep 29, 2010 08:19 PM
