Need advice on lowered 92 accord
Old Jul 1, 2007 | 10:47 AM
TopEndUSA's Avatar
Default Need advice on lowered 92 accord
I lowered my car with the skunk2 race springs (approx. 2 inch drop) The front wheels have a negative camber of course now. It leans in at the top. Do you recommend that I just get another alignment, or do I need to install a camber kit? Thanks
Old Jul 1, 2007 | 11:02 AM
oodie's Avatar
Default Re: Need advice on lowered 92 accord (MardreRacing)
Alignment will help but camber kit will fix it.
Old Jul 1, 2007 | 11:25 AM
203Cree's Avatar
I would highly recommend the Ingalls kit for the front and rear both. Quality stuff. I'm dumped way low on H&R C/O's and that's what I'm using. Easy to intall and have good adjustability.
Old Jul 1, 2007 | 01:37 PM
TopEndUSA's Avatar
Default Re: Need advice on lowered 92 accord (203Cree)
Which Ingalls kit are you talking about? The one that's a balljoint? or the one that has two pieces that goes on the A arm?
Old Jul 1, 2007 | 01:59 PM
203Cree's Avatar
I run the A Arm mount kit. The balljoint kit works too I guess, can't really give ya any feedback on it tho. Just make sure you get the right kit. I belive this is the one you'll want to run to get the camber close to being back to zero or just a tad neg...
Linky
I run the other one they have, but I'm setup for autox and road course.
Old Jul 1, 2007 | 04:42 PM
JDM_DC4_Fanatic's Avatar
There is no factory camber adjustment for your car, same as mine. The only way to get camber adjustment is with an aftermarket kit. I do not recommend the balljoint type kits. we have installed a few at the shop, and they all come back.
Old Jul 1, 2007 | 07:56 PM
TOP END MS's Avatar
I recommend no camber kit and just getting a standard alignment to correct toe.
Old Jul 2, 2007 | 05:42 AM
TopEndUSA's Avatar
Default Re: (TOP END MS)
Really? Won't the wheels still lean inward causing the inner thread of the tire to wear quicker?
Old Jul 2, 2007 | 01:24 PM
D16Z6racing's Avatar
Default Re: Need advice on lowered 92 accord (oodie)
I'd run a camber kit.
Any of my cars over 1.5 drop get a a camber kit. One of my Civics and one of my Accords are at 1.5 with just alignment. Another one of my Accords (2.0) and my CRX (2.5) were using a camber kit.
Becky T
Mar 4, 2011 09:20 AM
attica
Suspension & Brakes
17
Mar 18, 2010 11:31 PM
19Accord97
Suspension & Brakes
10
Apr 3, 2009 07:30 PM
94RedEGCoupe
Jul 4, 2004 08:33 PM
clutch33
Oct 29, 2003 04:54 PM
