Help - Converting DPFI to MPFI - JDM B16A to 91 Civic STD
Old Jul 1, 2007 | 08:48 AM
daniels's Avatar
Default Help - Converting DPFI to MPFI - JDM B16A to 91 Civic STD
I need to know which pins on the PR3 computer are for the 4 injectors. I have the pins for the oxygen sensors and the VTEC switch/solenoid. Got 4 wires from the injectors that go into the computer and don't know where they go.. any help?
Old Jul 1, 2007 | 08:57 AM
VtecSyndrome's Avatar
Default Re: Help - Converting DPFI to MPFI - JDM B16A to 91 Civic STD (daniels)
man....here come the flames.
Dude this is sooooo easy to find when you actually try to search. because I'm in a good mood I'll tell you the direct links for info you need. (A3 and A7 are the wires you need to cut and run to injectors)
Links:
http://effinmotorworks.com/Effin_MPFI_swap.htm
http://www.angelfire.com/d20/h....html
http://www.geocities.com/teampimports/fuelinj.html
http://www.geocities.com/c_rexboy/mpfi.html
....now awaiting mass amounts of flamage...........
Old Jul 1, 2007 | 09:13 AM
daniels's Avatar
Default Re: Help - Converting DPFI to MPFI - JDM B16A to 91 Civic STD (VtecSyndrome)
hey man thanks alot.. im a bit computer illiterate so i couldnt find anything searching.. vtec civic here i come!
team_lunatics
19
May 24, 2010 09:30 AM
mugen12_35sec
Jun 3, 2008 08:31 PM
My_EFsedan
175
Apr 27, 2007 08:43 AM
honcrx91si
Aug 9, 2005 01:22 PM
static_signal
Jun 11, 2004 01:43 PM
