B18C5 swap comming soon, should i convert wiring?
Old Jun 6, 2002 | 11:42 PM
JDMBOLONI's Avatar
Default B18C5 swap comming soon, should i convert wiring?
my container is comming in a week and i will be putting my B18C5 w/ Y1 into my crx. currently i have a pr3 and i was going to just chip and use that, but is it worth it too convert it to obd1 or 2? if i convert it what are the benifits? i was just thinking of using a B16A1 intake manifold and TB because that would keep things simple like a B16 swap and really not have to change the wiring. (my motor is just a long block, not complete). so what should i do???
thanks
Mike.
oh yeah and theres 4 more B16B and B18C5 longblocks for sale......$4500-$5500 CDN
Old Jun 7, 2002 | 03:50 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: B18C5 swap comming soon, should i convert wiring? (JDMBOLONI)
get the PR3 ecu rechipped and you'll be fine.
that's what I have.
No problems here.
182 Hp at the wheels
Old Jun 7, 2002 | 05:22 AM
Radex's Avatar
I have B18C6 (Euro) stock ECU and can tell you it is a pain in the *** to do wiring. I swapped everything from underhood cables, fuse boxes to dashboard wiring. I don't know if you can chip PW0 to act exactly like B18C6 stock ECU but if you can, do it! The only benefit of B18 ECU is service plug I believe. But! if you can't put B18 software into PW0 I would consider this *** job.
Old Jun 7, 2002 | 06:24 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Why the Y1 tranny?
Wouldn't the JDM S1/J1 be better-suited for the B18C5's powerband?
The J1/S1 has the same gearing (except for 5th) as the USDM ITR tranny and it also has the same 4.400 FD rather than the Y1's 4.26.
Just a thought, but I'd go with the J1 or JDM S1 tranny if it were me.
Old Jun 7, 2002 | 01:24 PM
Nossy's Avatar
Default Re: B18C5 swap comming soon, should i convert wiring? (B18C5-EH2)
if you spent all the money going with the c5, doesn't it make sense to spend a little extra time (or money, just get the harness) to convert it and run it on what it was made to run on?
Old Jun 7, 2002 | 03:29 PM
The_Brian's Avatar
Default Re: B18C5 swap comming soon, should i convert wiring? (Nossy)
you can use the pr3 ecu you will have to get a 1st gen b16 distributor (white plug) or you can have someone like place racing make a conversion harness... i think it will run fine with a reprogrammed pr3
[Modified by JDMinPorterville, 12:31 AM 6/8/2002]
salman
Jul 15, 2008 03:02 PM
Soon2DriveACivic
Jun 11, 2005 12:56 PM
stefan
Mar 25, 2005 02:24 AM
