Drop, camber, alligment oh my
Old Jun 30, 2007 | 07:20 PM
climb_on's Avatar
Default Drop, camber, alligment oh my
I recently instaled some H&R sport sprigs on my 2001 gsr
i also just go a brand new set of yokohamas
i researched and found that with these springs i wouldnt need a camber kit, and that it woud all be able to get fixed with an alignment.
i really would like my tires to last. So i knew a alligment was i order
went to pepboys (ya i know how they are) today was told they can adjust toe but the wouldnt be able to do anything about the camber.
here is a picture of my ride as you can see the camber isnt too bad. shouldnt an allignt be able to get it back to 0 degrees.
so should an alligment do the job?
Old Jun 30, 2007 | 07:26 PM
alexisthemovie's Avatar
you dont need a camber kit. as long as your toe is set to factory spec, your tire wear will be fine. be sure to rotate often.
Old Jun 30, 2007 | 07:27 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Drop, camber, alligment oh my (climb_on)
Oh, it'll still eat away at your tires, just not as drastically.
Even a moderate drop like that can cause camber wear,
I had new tires on, and even my back tires which were not as low showed some camber wear.
Old Jun 30, 2007 | 10:17 PM
Turbo(less)DB8's Avatar
Default Re: Drop, camber, alligment oh my (CleanLikeJdm)
This is untrue. I have much worse camber then this. I got new tires and did an alignment. and I have NO camber wear, I must say tho, I once thought this once, despite what everyone on h-t said. Then I had proof.
Old Jul 1, 2007 | 12:59 AM
Doostur's Avatar
Get skunk 2 up front and use washers in the rear. Go get an aligment and have them check your toes too. Bam your golden. I would do it even if the tires "look" good. Cause after 5,000 miles of rolling slightly slanted, nothing will "look" good
Old Jul 1, 2007 | 07:22 AM
climb_on's Avatar
Default Re: (Doostur)
should they be able to adjust the camber at all?
cas
Old Jul 1, 2007 | 08:30 AM
Hype-R Stalker
Default Re: Drop, camber, alligment oh my (Turbo(less)DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo(less)DB8 &raquo;</TD></TR><TR><TD CLASS="quote">This is untrue. I have much worse camber then this. I got new tires and did an alignment. and I have NO camber wear, I must say tho, I once thought this once, despite what everyone on h-t said. Then I had proof.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Oh, it'll still eat away at your tires, just not as drastically.
I had new tires on, and even my back tires which were not as low showed some camber wear. </TD></TR></TABLE>
Does this sound like something someone said on HT?
No, it's personal experience..
And I wasn't even close to tucking tire either.
Old Jul 1, 2007 | 08:55 AM
JonGP4's Avatar
Default Re: (climb_on)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on &raquo;</TD></TR><TR><TD CLASS="quote">should they be able to adjust the camber at all?
cas</TD></TR></TABLE>
There's no factory camber adjustment.
You can not adjust the camber without a "kit" of some kinda, whether is be washers or controls arms.
Some people say alittle neg cam won't affect tire wear if the toe is set to 0, I however had different experiences. Lowered on prokits for about 3 years and 50k miles i went through 2 sets of Kumho 712s and 2 sets of HP4s. All were rotated every 5k and balanced. I drive hard, but every time i'd replace them they did show signs of camber wear. I had the car aligned twice a year at Sears because they had a lifetime warranty on it. On the other hand my friend had the same car and same springs as me (cheaper shocks tho) but with a camber kit and went through 1 set of YK421s in 40k miles. No camber wear he also did a h22a swap mid way through.
If I had to do it over again i'd get camber kits, would have saved me about 800 bucks in tires.
Old Jul 1, 2007 | 01:04 PM
JDM_CRX_PLEASE's Avatar
if u wanted ur tires to last then u shouldnt have droped it.
XplodeTeg
Jul 27, 2010 11:04 AM
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
Jesterian
Sep 28, 2006 08:05 PM
HatchBox
12
Jan 14, 2003 09:15 PM
seineil
Jul 30, 2002 11:26 PM
