prelude SH swap options ?
Old Jun 30, 2007 | 06:24 PM
civicgeek133's Avatar
Default prelude SH swap options ?
alrite well i have always owned civics so ludes are new to me well i just spun a rod bearing in my 97 prelude sh what are my options are far as motor swaps which motors can i put in and will the tranny in my car the one with the atts will that bolt to any other h22 blocks basically i want to know what motor/ tranny combo will work to swap in my car will all factory mount and stuff besides buying the same motor that came factory i really want a euro R motor or type s motor thanks alot
Old Jul 1, 2007 | 07:10 AM
joehonda's Avatar
Default Re: prelude SH swap options ? (civicgeek133)
the type s will be a direct bolt on. I believe the type s is obd 2 and is compatible to your tranny also. correct me if I am wrong though. anyways, good luck.
Old Jul 1, 2007 | 08:54 AM
P13_mein's Avatar
Default Re: prelude SH swap options ? (joehonda)
the H22 from a genuine type-S is the only viable upgrade; & what an upgrade it is
but you'll be getting it with a transmission anyway.
but that is the only other h series that will bolt up and allow you to retain your ATTS
u could always rebuild your engine with type-s parts tho, for a fraction of the cost
Old Jul 1, 2007 | 07:31 PM
Default Re: prelude SH swap options ? (P13_mein)
well i jumped my car to obd-1 so i lost my atts option anyway lol so if i was to get a complete h22a swap would the new motor trans and axles and eveything bolt directly into the car with out any modification ??
Old Jul 1, 2007 | 09:41 PM
P13_mein's Avatar
yep...
Old Jul 2, 2007 | 06:59 PM
bump what kind of dyno numbers do h22's with type s pistons usually net compared to ur typical h22a4
Old Jul 3, 2007 | 07:56 AM
shrirag's Avatar
well a type S engine has about 220 hp vs. 200 on h22a4's, but that includes pistons and cams (I am not pos if there is anything else really). So you'll probably see a few more whp since you are running 11:1 compression instead of 10:1 now.
Old Jul 3, 2007 | 11:52 AM
NirVTEC's Avatar
Default Re: prelude SH swap options ? (shrirag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgeek133 &raquo;</TD></TR><TR><TD CLASS="quote">alrite well i have always owned civics so ludes are new to me well i just spun a rod bearing in my 97 prelude sh </TD></TR></TABLE>
Over time its looking more and more like the H22A4's are inferior to H22A1's and 1st gen H22A's......
I feel like alot more people have had bearing problems with newer H's...
Just sharing something I have been thinking about for years.....
Old Jul 3, 2007 | 08:16 PM
Default Re: prelude SH swap options ? (:=:NirVTEC:=:)
BUMP ! anyone have a good h22 crank they want to sell ?? or know where i can buy a forged crank such as eagle like they make for the b series engines thanks
Old Jul 4, 2007 | 07:11 AM
NirVTEC's Avatar
I have a freshly balanced H22A4 crank at my shop. I will have to measure it as I think its a 55mm(98-01) crank. I will be in touch.
Old Jul 5, 2007 | 03:30 AM
alrite man thanks alot just let me know
vbolz
Apr 10, 2011 10:30 AM
JUDO_ED
Dec 15, 2009 01:53 PM
silentvoice19
Mar 6, 2007 02:35 PM
hondaguy6513
Sep 29, 2005 08:29 PM
scootertribe
Aug 17, 2005 11:19 AM
