b16 downpipe Question
Old Jun 30, 2007 | 03:17 PM
crxsleeper210's Avatar
Default b16 B pipe Question
i just got an obd0 b16 exhaust manifold but i need the downpipe. can i use a 2nd gen b16 downpipe or do i need the 1st gen downpipe? i cant find the 1st gen one anywhere
Modified by crxsleeper210 at 4:36 PM 6/30/2007
Old Jun 30, 2007 | 03:29 PM
89s1's Avatar
Default Re: b16 downpipe Question (crxsleeper210)
i think you mean the B pipe, the second half of the exhaust manifold past the engine.
if so, then you can use a second gen one no problem as far ans the bolts to piece it together, but it may be a bit longer or shorter, however i would doubt that.
one question tho, why did you change manifolds in the first place?
Old Jun 30, 2007 | 03:35 PM
Default Re: b16 downpipe Question (89s1)
well when i first got my swap i had my mechanic install a megan 4-1 header but after a week i didnt like how low it hanged and i wanted to put it back to stock until i go turbo. I had the stock manifold that came with my motor in the garage and for some unknown reason my mom cleaned out the garage and threw it out!!!! So i finally found a stock obd 0 manifold and now i need the b pipe.
Old Jun 30, 2007 | 04:00 PM
EFSiR's Avatar
Default Re: b16 B pipe Question (crxsleeper210)
If your're talking about the A-pipe, the the one right under the oil pan, you can! I've used one from 2000 B16 US motor. Of the 3 bolts, 2 have to be modified. it all fits great the OEM 1G JDM manifold (with 2 oxygen sensors) and flows much better then the 1G one as it's bigger than the 1G JDM A pipe. I have my old unit, if interested PM me. Oh, keep in mind that if you're gonna get an aftermarket JDM headers (any Jasma approved) and have HASPORT mounts, the piping is hard to allign with the catalitic converter as the motor tilts forward and the piping tilts upwards. ARRRRH, that 's my problem now.
HTH
Old Jun 30, 2007 | 04:13 PM
Default Re: b16 B pipe Question (EFSiR)
so you do have the original 1st gen b16a b pipe (the one coming from the exhaust manifold to the cat)? if so pm is sent to u
91blksi
Jun 6, 2005 06:41 AM
insomniac791
Nov 10, 2003 09:38 PM
