CRX Electrical Problem, Need help. I've researched, cant find anything. Please help.
Old Jun 30, 2007 | 01:38 PM
91SiSEZCT's Avatar
Default CRX Electrical Problem, Need help. I've researched, cant find anything. Please help.
Hello everyone, this is my first post on this forum. I am having a weird electrical problem with my car. My work is about 10 miles away from my house. I am able to get halfway to my work and the car dies. I have to pull the car over, wait a minute or so, and the car will start up again. The car will act up 1 more time before I can get to work.
Something like 2 min after it died. When the car dies, It is just the engine, the whole electrical system is up, all my gauges light up, but the rpm needle is dead..... I am able to crank the car over, but it wont fire. After waiting a minute or so it will fire up.
I've researched on the web some problems relating to a no start condition and have ruled out, Main Relay, Ignition switch, Battery, Grounds (have all been re-done) I have a 91 Si With a ZC Turbo, MSD SCI Ignition with Blaster SS coil. The MSD system has 3000 miles on it. My fuel pressure gauge indicates I have full fuel pressure while trying to start the car, so I think the car is getting fuel.
I can also let the car idle for like 15 minutes and the car will just die. Same thing, have to wait the minute before trying to start it.
I have no idea what it could be, can you guys offer any suggestions on where I can start?
Thanks,
Chris
Old Jun 30, 2007 | 01:54 PM
ChickenH's Avatar
Without checking for spark and to see if the injectors are firing i would say: Ignitor and or coil since you already did the main relay.
Old Jun 30, 2007 | 03:34 PM
89s1's Avatar
Default Re: (ChickenH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChickenH &raquo;</TD></TR><TR><TD CLASS="quote">Without checking for spark and to see if the injectors are firing i would say: Ignitor and or coil since you already did the main relay.</TD></TR></TABLE>
i second this and will lean more towards ignitor than coil as well.
my suggestion ideally would be a whole new dizzy off a donor car for a test drive.
Old Jul 1, 2007 | 04:05 AM
91SiSEZCT's Avatar
Default Re: (89s1)
Thanks for the suggestions. I doubt it is the coil aswell, like I said before, it is pretty new. Only 3000 miles on it... It seems as though something is getting hot and cooling down. It will only work after it has cooled down. After the car dies, I put my hand on the MSD box and coil, and they do not seem to be hot at all.... How does the ignitor work? and how would it be getting hot and cooling down??
smoothludey2
Apr 7, 2005 07:47 AM
94PearlWhiteGsr
Nov 1, 2004 07:38 AM
Vero
Feb 1, 2004 03:25 AM
ricodemus
Mar 4, 2003 03:18 AM
