how to tune cam gears for stage 1 shaft
Old Jun 30, 2007 | 12:50 PM
touintegra's Avatar
Default PLEASE HELP..how to tune cam gears for stage 1 shaft
92 hatch runs like ****....w/gsr.....think it needs tuning.....4 the time being want to know how to tune cam gears w/stage 1 sk2 shaft.......any ideas, low on money......got fuel rail, walbro pumps( highest one on the market) single crank pulley, stage 3 clutch, act fly wheel, stage1 shaft sk2....and still runs like ****....15's........i need help on which ways to turn the cam gears on each shaft.
Old Jun 30, 2007 | 12:56 PM
Padawan's Avatar
Darth ModerVader
Default Re: how to tune cam gears for stage 1 shaft (touintegra)
Your problem is not the cam timing, which I would suggest just leaving at 0,0 for now. The main issue is:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by touintegra &raquo;</TD></TR><TR><TD CLASS="quote">got fuel rail, walbro pumps( highest one on the market) stage1 shaft sk2....</TD></TR></TABLE>
As you have already stated, the setup does need actual tuning to run properly. I suspect your fuel pump is significant overkill, and certainly not helping the situation.
Old Jun 30, 2007 | 02:39 PM
DB1_559's Avatar
Default Re: how to tune cam gears for stage 1 shaft (Padawan)
^^^^ wat he said you got to much fuel going with a stock motor
Ariddle25
Nov 11, 2009 06:56 AM
chadalac1712
May 10, 2007 06:43 AM
9341civic
May 19, 2005 03:47 PM
Kelvin96GSR
May 23, 2003 02:49 PM
