Intermittantly decides not to start?? Possible problems? No CEL (94 EG EX Coupe 5spd)
Old Jun 30, 2007 | 11:17 AM
99ssinoc's Avatar
Default Intermittantly decides not to start?? Possible problems? No CEL (94 EG EX Coupe 5spd)
Fixed!! Stupid Main relay!
Modified by 99ssinoc at 6:45 AM 7/2/2007
Old Jun 30, 2007 | 12:28 PM
99ssinoc's Avatar
Anyone??? I'm now thinking fuel pressure regulator..
Old Jun 30, 2007 | 02:18 PM
forcefedferio's Avatar
Default Re: (99ssinoc)
firing up the parts cannon already?
main fuel relays are notorious for this in 5th gens, my turbo civic does it time to time. if you're going to start somewhere start with that they are i believe $40 from honda and only a couple bucks at a junkyard.
as for the FPR pull the vacuum line off, if there is fuel it is bad anyway, replace it accordingly, if fuel doesnt come out it is most likely still good.
Old Jun 30, 2007 | 02:20 PM
Default Re: (forcefedferio)
oh and being that you bought this car not long ago it's always a good idea when you first buy a car to do the normal maintainence things because you never know when they were done last...plugs,wires,cap,rotor,filters...etc. Maybe also take a look at the condition of the Timing belts and all accessory belts.
JDM-sol 89
Feb 14, 2012 01:50 PM
Bush-15
Aug 23, 2009 02:39 PM
jimmy o.
May 8, 2009 08:48 AM
ulyschav
Jul 22, 2008 06:16 PM
jury
Jan 1, 2007 10:57 AM
