Compustar 2wss-as Alarm Remote Start installation premeditated wiring connection
Any advice and suggestion are welcome.
Vehicle color code wiring diagram: http://www.pl-us.com/ACURA/WiringSpecs-TSX.pdf
Connector 1
Red +12 V constant --> white +12v Battery ign harness or dedicated + power wire to battery?
grn/wht +pking light out --> + red/black parking light
red/wht +12v constant --> white +12V Battery (same as above?)
red/wht (second wire) --> goes to second relay
WHT accessory --> WHT/RED Accessory ign
pur pre wired--> goes to starter kill relay
YEL pre wired --> goes to the starter kill relay
GRN/RED ign --> BLK/yel Ignition 1
blk ground --> chasis ground
Starter kill relay
from relay yel/blk(30) --> starter side BLK/WHT
from relay yel (87a)--> key side blk/wht
Second relay (not sure which sliced end connected to which part of the wire relay )
pur pigtail (85 on relay)--> Black/Red Ignition 2
blu pig tail (30 on relay)--> Black/Red Ignition 2
Connector 2
grn/wht - pking light --> - black/red parking light
blk status - wire out --> ???
grn - ign output--> purple wire (85) of second relay?? <--need advice
wht/blk - acc output--> nothing? <--need advice
red/blk - starter output--> nothing <--need advice
connector 3
lt blue - parking brake in--> at parking break switch grn/orange
gry/blk hood pin --> hood trigger green/black
lt blu/wht brake --> brake switch white/black
pur/blk trunk pin--> blue/black trunk trigger
red/wht door - trigger --> - trigger wire all wires to one?? (LF latch, RF latch, LR, RR latch connected as one?)
yel/blk tach engine sensing input --> Blue tach wire
connector 4
blu unlock --> pink/blue door unlock
blu/blk --> pink/black door lock
connector 5
orange - rearm --> - white/red alarm arm
orange/white - disarm --> - white alarm disarm
violet - dome light supervision --> green/red - domelight supervision (also noted as all door trigger, should I hook up the red/white - door trigger to this connection also?)
The rest of wire connection are straight forward (siren, led, horn, shock module) so I'm okay with those. Now should I require diodes and at which connection
Any help is greatly appreciated.
~Dylan
Connector 1
Starter kill relay
Connector 2
connector 3
connector 4
connector 5
~Dylan
dafuzzbudd
Audio / Security / Video
13
Oct 4, 2008 03:52 PM
donz
Jun 25, 2007 11:13 PM
