Throttle body tension adjustment, is it possible???
Old Jun 30, 2007 | 08:55 AM
greenDC2's Avatar
Default Throttle body tension adjustment, is it possible???
Has anyone put a tighter spring in their throttle body, or found any way to make the throttle open and close at a faster rate? Thanks!
Old Jun 30, 2007 | 10:42 AM
satitus's Avatar
Default Re: Throttle body tension adjustment, is it possible??? (greenDC2)
If it is a B series TB you can set the perch at a position higher than stock. Hard to explain but the bottom part of the spring perch can be basically tightened and set closer to the top perch. It is a little tricky getting the pulley back on with a tighter spring but it is possible to do. I was wondering the same thing about a tighter spring (can you get one, etc) but this method works, too.
Old Jun 30, 2007 | 10:56 AM
greenDC2's Avatar
Default Re: Throttle body tension adjustment, is it possible??? (satitus)
How many additional turns can you get out of your spring? I tried that method be the spring just started binding up.
Old Jun 30, 2007 | 11:08 AM
satitus's Avatar
I think the spring only goes maybe 20 to 30 degrees tighter to get to the higher perch.
Old Jun 30, 2007 | 11:11 AM
greenDC2's Avatar
So did only 20-30 degrees change the throttle feel??
Old Jun 30, 2007 | 11:16 AM
satitus's Avatar
It did for me, throttle is much snappier. Hopefully the spring holds up to the extra tension. No problems for about a year.
Old Jun 30, 2007 | 11:21 AM
greenDC2's Avatar
Nice, well i appreciate the help, i'm gonna try it on my JG TB tommorow!
Old Jun 30, 2007 | 12:26 PM
SkankyEJ7's Avatar
i did an extra one or maybe two turns on my friend throttle body and that bitch felt like the clutch then i changed it back after he felt it
e30FTMFW
Nov 20, 2008 12:25 PM
Dang EG
Nov 7, 2007 09:55 AM
civperc
May 18, 2004 11:13 PM
HT Chaplain
Apr 27, 2004 03:55 PM
