turbo gsr and knock sensor issues
i have a turbo gsr and im problems with my knock sensor sending me into limp mode. what should i do. i have heard not to just disable it because that can cause more problems down the road. i run 93 octane and the ignition timing is set conservatively at 14 degrees
if i stay in vacuum until 5000 then i can floor it and go. but if i floor it before then it will go into limp mode. weird...
I disable it most of the time. My buddies car used to do that same ****, on **** load of the compression, 100 octane and conservative timing. So I just disabled it and the tune turned out fine.
ive never run a knock sensor. ive got over 40k miles of turbo over the past few years with only 1 motor casualty due to a huge boost spike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jorge59la »</TD></TR><TR><TD CLASS="quote">i had the same fk'n problem. get a chipped p28 ecu with a conversion harness obd2a>obd1
+1 and a dyno tune
</TD></TR></TABLE>+1 and a dyno tune
well the timing was originally at 16 degrees and i backed it off to 14. its running a little better. i need to just get it tuned and screw this basemap. going in 2 weeks for the tune
B18CmeFLYby
Feb 29, 2008 01:12 PM
AnAccordIsForever
Jan 24, 2006 11:13 AM
