which fuse?
91 Civic hatch, has a draw on the battery and if I remove negative cable and touch it to the battery post, I hear a click in the passenger door. Does anyone know what this click is from and what fuse to pull to check and see if this is the battery draw? Door ajar light is on when car is running and all doors closed.
the click is normal...this will not affect the battery drain. Clicking releases the seatbelt when it gets power. if you unplug the power from the seat belt . the seat belt will lock up. It could just be a dead cell in the battery. One bad cell can make the whole battery drain .try getting a new battery.
Wow! A response after 7 days, I guess I should have kniwn I would get a response! Actually I disconnected the wiring in the right door and my problem was solved, no more dead battery. It seems the door ajar light and the seatbelt mechanism in this door had been clicking and flashing for a while which leads me to believe the wiring to the door has grounded out somewhere. Thank you for your response sir!
crx_si91
Mar 9, 2014 11:40 AM
