hood spacers
Old Jun 29, 2007 | 07:00 PM
I CRX I's Avatar
Default hood spacers
how have you guys placed your hood spacers?!? any pics of where you placed them and about how long are the bolt youve gotten? i have a gsr in a crx right now and no dough or a tool to cut
Old Jun 29, 2007 | 09:38 PM
doublethink's Avatar
Default Re: hood spacers (I CRX I)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I CRX I &raquo;</TD></TR><TR><TD CLASS="quote">how have you guys placed your hood spacers?!? </TD></TR></TABLE>
hopefully none.
you can cut your hood with a hacksaw blade held in your hand, go diggin in friends cars for quarters and get a hacksaw blade, and notch it out.
borrow a dremel from a neighbor.
pray to the gods for something sharp...
do it right or don't do it at all.
Old Jul 2, 2007 | 08:04 PM
I CRX I's Avatar
yea...hack my hood as supposed to just lifting it slightly?? i'd rather not. i like keeping away from shap metal objects unless its absolutley neccassery &lt;--spell check) to use. any pictures or tips?!? please help
Old Jul 2, 2007 | 08:07 PM
Crx Jimmy's Avatar
Default Re: (I CRX I)
Just go to the hardware store you need 6mmx1.0 bolts If you use 1" spacers get bolts 1" longer than stock I know its ghetto, but I have it done for functionality, My supercharger lives behind the motor and gets uber hot. with the hood gangsta leaned and propped up 1" in the back it drops blower temps 10 degrees!
Old Jul 2, 2007 | 08:15 PM
fourdOOrEF2_F.D.W's Avatar
like this??? about 1 inch high
Old Jul 3, 2007 | 01:38 AM
My_EFsedan's Avatar
Default Re: (fourdOOrEF2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourdOOrEF2 &raquo;</TD></TR><TR><TD CLASS="quote">
like this??? about 1 inch high</TD></TR></TABLE>
mines that same thing, i used washer like 7 depending on how thick it is, my buddy used sockets, yea sockets, and my screws came from my interior..haha, i just found it
Old Jul 3, 2007 | 04:51 AM
Autoworks's Avatar
Default Re: (My_EFsedan)
Had to raise mine to clear the valve cover vents.
I used custom aluminum spacers, thought about wselling them as sets....but never made it past that first thought.
Old Jul 3, 2007 | 09:19 AM
i work on copy machines.. so i used sum white paper rollers work perfect.!!!
Old Jul 3, 2007 | 10:03 AM
Smokinsax's Avatar
The Boot
Default Re: hood spacers (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">
hopefully none.
do it right or don't do it at all.</TD></TR></TABLE>
lol...you sound like an idiot.
I had to do this even AFTER cutting out the "webbing" on the underside of my CF hood.
I have my hood raised in the rear about a half inch...not as extreeme as some ive seen. I went to Home Depot and bought some nylon spacers in the hardware dept. Works like a charm.
more pics here if you want different angles to look at:
https://honda-tech.com/zerothread?id=2003677
Old Jul 3, 2007 | 10:24 AM
Autoworks's Avatar
Default Re: hood spacers (Smokinsax)
^^ that is one good looking CRX
Old Jul 3, 2007 | 10:28 AM
crazykamper's Avatar
^^deffinetly..... you ever gonna make those aluminum spacer things??
Old Jul 5, 2007 | 04:10 PM
I CRX I's Avatar
anybody ever have problems closing hood? can i have some bolt sizes and thread counts if possible?!?! and more pictures please :-D
Old Jul 5, 2007 | 04:19 PM
janz3n's Avatar
you guys raising from the hing atached to the hood or to the frame? cuz i did mine to the hood and i used the original bolts.. not alot of lift though.. maybe half to quarter of an inch
Old Jul 5, 2007 | 04:48 PM
I CRX I's Avatar
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">you guys raising from the hing atached to the hood or to the frame? cuz i did mine to the hood and i used the original bolts.. not alot of lift though.. maybe half to quarter of an inch
</TD></TR></TABLE> please elaberate a little more on that?? i asumed the only way to raise it is by buying longer bolts that bolt to that actual hood itself
Old Jul 5, 2007 | 05:02 PM
janz3n's Avatar
k. theres two bolts on each side of the hood. if you only put washers on the bolt closest to the windsheild on each side it should work because the bolt is longer. but i dont know how much you can raise it like this without having to buy new bolts.
Old Jul 5, 2007 | 05:20 PM
rbwdriven's Avatar
figure I'll help you guys out.
http://www.mcmaster.com
Part Number: 92510A765
they are $1.54 each.
alumiunum 1/2" long, 1/4" i.d., 1/2" o.d.
Mcmaster Carr is a great place to find the odds and sods your looking for.
Being an Engineer, I cna find stuff on that site all day long.
Old Jul 5, 2007 | 05:52 PM
janz3n's Avatar
Default Re: (rbwdriven)
why order somethign when you can buy washers and do it the same day?
Old Jul 5, 2007 | 08:47 PM
TEAM JDM-P's Avatar
actually get them same 10mm bolts but fairly long ones remove the hood thingy hing i cant spell it then buy skateboard bushing the DOh-DOhs work best what ever color u prefer lol and use them gives the hood flex with the wind and doesnt damage the hood hinged thingy i cant spell. gives u about an inch of lift looks decent not too crazy.
Old Jul 5, 2007 | 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">
you know damn well you should have an sir style hood on that thing instead of propping it.
wonderful car none the less, x100000 times nicer then mine. no hate here, just a genuine feeling that a cars lines shouldn't be sacrificed because a hood doesn't clear an engine.
Old Jul 5, 2007 | 09:18 PM
661rex89si's Avatar
hopefully none.
some people rather not ruin there hoods or have expensive cf hoods hacked up. its sometimes easier to just get spacers and it doesnt even look bad at all. and yeah your right a sir style hood would help some but for the budget guy spacers help.
Old Jul 5, 2007 | 09:32 PM
Default Re: hood spacers (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si &raquo;</TD></TR><TR><TD CLASS="quote">
some people rather not ruin there hoods or have expensive cf hoods hacked up. its sometimes easier to just get spacers and it doesnt even look bad at all. and yeah your right a sir style hood would help some but for the budget guy spacers help.</TD></TR></TABLE>
hack what?
have you ever seen a fiber images hood?
whoops, no underwebbing.
all im saying is, if you CAN trim your stock hood to make things work, you should always try to do that first.
even if lets say you trim the webbing, and it still doesnt clear, now you dont have to ghetto fabulous with as many washers.
im just not into corner cutting, but if your option is:
1) prop the hood
or
2) not have a running car
obviously you do what you have to do and thats it. but the OP seemed to be saying he has no tool to even trim the hood with and thats why hes buying washers, which is why i said what i said.
its totally an opinion, and its a free country the man can do whatever he wants its his car.
Old Jul 5, 2007 | 09:45 PM
661rex89si's Avatar
hack what?
1) prop the hood
or
its totally an opinion, and its a free country the man can do whatever he wants its his car. </TD></TR></TABLE>
i guess its a preference thing and you bring up some good points.and yes im no idiot when it comes to fiber images there down the street from me and i know how awesome and space saving there hoods are. but there not cheap
Old Jul 5, 2007 | 10:10 PM
i guess its a preference thing and you bring up some good points.and yes im no idiot when it comes to fiber images there down the street from me and i know how awesome and space saving there hoods are. but there not cheap</TD></TR></TABLE>
Understandable. You are 100% correct, it is only a preference after all.
Look, I totally understand if its not enough to trim and you have to make desperate moves.
What I don't agree with is everyone says "hack" in this therad, but you <u>can</u> do a really nice job with it. If you goon hand your ****, then whats even the point of worrying so much how it looks because thats obviously a reflection of how you've worked elsewhere on your car.
It seems to conflict a bit for me when someones like "I don't want to trim something people will never see, so i'll permanently change how the front of my car looks to compensate for this."
So essentially 85-90% of the people who look at the car, meaning not honda guys, will think you rear ended someone at low speed and didnt get it fixed yet.
I am just being devils advocate and not trying to start arguments, I just felt the opposing viewpoint should have its fair say.
Despite its apparent unpopularity.
And yes, I am aware that guys do it to keep their temps down, but I have my own opinion about ducting fresh air into the engine bay to compensate for that as well, which also has got me yelled at before.
All in all, when the day is done, people do what they like, and thats how it should be. I have no qualms with that, but that won't stop me from trying.
Old Jul 6, 2007 | 02:38 AM
~sp33~'s Avatar
EFB055
My engine actually rubs on the top panel of the hood, not the webbing.. Ive been meaning to prop it but never had a chance, my timing belt cover is wearing away the metal, one day it will make its own hole lol.
Old Jul 6, 2007 | 03:23 AM
DaNnYsEvEn's Avatar
Default Re: (~sp33~)
its fine if it serves a purpose, but if you don't need it why destroy the body lines?
i guess some people do it for show? my buddy raised his hood for no apparent reason and bragged about it as if it was something "cool". he had a sohc zc in btw lol
