???? HELP!!!! What kind of paint should i use to paint my headlights????
krylon has a stained glass spray paint, and im pretty sure it comes in yellow. i jus dont know how it would hold up. plus i think you can only order it through their website, cause ive checked and no stores have them.
I also want to know the steps on doing this, Because as easy as it may seem, I know there are some tips and tricks that will probably make this "Easier than it already is"
Please do yourself a favor and take the lens off the headlight and paint the actual refector. It sounds as if you are just painting the lens. It won't look good.
I haven't bought the yellow stained glass stuff but i bought some red at michaels, it was $5 or so.
Ladies and gentlemen we are floating in space...
Yeah...just paint the reflector inside. If you really need to do the cover, order a sheet of Lamin-x. At least that stuff will be even and won't get chips in it.
How can i remove the headlight from the plastic without breaking it? I know that sounds like a stupid question but the brackets that hold the plastic and the glass are pretty hard to get off without chipping the glass. . . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-VRex »</TD></TR><TR><TD CLASS="quote">How can i remove the headlight from the plastic without breaking it? I know that sounds like a stupid question but the brackets that hold the plastic and the glass are pretty hard to get off without chipping the glass. . . . .
