what do you use to log knock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denn »</TD></TR><TR><TD CLASS="quote">i'm use CromePro</TD></TR></TABLE>
the knock sensor can be used with <crome> to detect knock as i am sure any other aftermarket ECU program can be used with a OEM knock sensor!
How do you like knock logging with crome Pro, I seem to get alot of noise midrange that it picks up as knock. Someone said it may just be engine noise that it is picking up and not knock at all.
12.2:1 c/r 93 octane VERY conservative timing maps Knock sensor is pulling 10 deg of timing right in the middle of my low cam map ~ 4k amd mid load. No audible knock that I can hear.
an2ny888
Sep 26, 2006 06:06 AM
Dragger817
May 22, 2003 11:54 AM
