damn seatbelt alarm..
Old Jun 29, 2007 | 12:35 PM
Allday07's Avatar
Default damn seatbelt alarm..
my seatbelt alarm will not stop buzzing in my 91 civic....seatbelts are buckled, doors are slammed shut. ive searched plenty of times, and everyone keeps saying to open up the rear view mirror which i did, nothings there...i unplugged the wires under each seat..still beeps...i looked for an hour under the dash for anything that looks like a buzzer/piezo speaker..nothing..
anyone who can find a true answer on how to shut that damn beep off will be so appreciated
Old Jun 29, 2007 | 12:38 PM
user 72830283's Avatar
your problem lies beyond that....are you sure there's nothing under you rear view mirror? but your ear near it when it beeps...
Old Jun 29, 2007 | 12:41 PM
Allday07's Avatar
Default Re: (pr3d)
i tried...i took the mirror down with the 3 screws that support it..nothing...i saw no wires whatsoever..and i tried putting my ear near things to try and catch the beep, i couldnt
Old Jun 29, 2007 | 01:11 PM
DenzComp's Avatar
It's up there man...I had the same problem as you. I put a new door on and had the beeping.
I don't remember 100% how where it was, but take those screws out.
I'm pretty sure that the plug is right there once you drop the mirror down.
I also had to pull my cluster and take the bulb for the flashing seatbelt light.
Old Jun 29, 2007 | 02:08 PM
tougetuned_ef's Avatar
Default Re: damn seatbelt alarm.. (Allday07)
hard wire the wires under the seat. thats what my buddy did when he put 00' si seats in his 4dr ef
Old Jun 29, 2007 | 02:31 PM
kcjohnnyboy's Avatar
check the fuses under the hood and under dash. i had the same problem, did everything and couldn't get it to go away. when my horn didn't work i checked the fuse for that and it went out. replaced it and the beeping stopped
Old Jun 29, 2007 | 03:25 PM
doublethink's Avatar
is it a sedan by chance?
i think only the crx's have it up in the mirror.
Old Jun 29, 2007 | 04:22 PM
Allday07's Avatar
Default Re: damn seatbelt alarm.. (doublethink)
thank you..finally someone agrees with me that its not in the mirror..lol
Old Jun 29, 2007 | 04:38 PM
gp70hs's Avatar
If you have a 91 sedan, I suspect you probably have those auto retracting seat belts. If you do, your beeping is coming from the seat belt controller which is mounted on the engine tunnel, to the left of the main ecu, on the passenger side of the car. Their is a pizo electric beeper in it. I don't think you want to unplug it, because it controls the belts.
I have been told that the dealer will fix anything associated with that seat belt system and that all you need to do is make an appointment to have them fix it. The seat belt system is apparently warranted for the life of the vehicle.
Good luck, that beeping is a royal pain in the ears.
Old Jun 29, 2007 | 05:10 PM
Allday07's Avatar
Default Re: damn seatbelt alarm.. (gp70hs)
thanks alot i appreciate it..if i unplug it..with the seatbelt at the highest position would that be safe? obviously if the door is open while i do it..the seatbelt with retract back to the lower position?
szczerbanator
Apr 27, 2009 06:14 PM
crx98
May 22, 2008 09:48 PM
Hondaholik
Dec 5, 2006 04:36 PM
quikflip27
Audio / Security / Video
Sep 11, 2006 08:30 PM
7808
Aug 25, 2004 02:29 PM
