B16a2 questions....
Old Jun 29, 2007 | 11:45 AM
love of the sol's Avatar
Default B16a2 questions....
I have a 1996 Del sol, and iI'm curious of 3 things...
1. How many gallons of gasoline does my car hold? is it 11 or 12? Just curious for my MPG.
2. How many quarts of oil does my engine take? Isn't it 4? I just did a change and I'm a just below the lower dot on my dipstick after putting four quarts in.
3. I think I need to do a radiator flush, it smells like someone peed in the reservoir tank to the left of the radiator. Its so gross, besides its a little low.
thanks
Old Jun 29, 2007 | 11:48 AM
ke98248's Avatar
Default Re: B16a2 questions.... (love of the sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by love of the sol &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1996 Del sol, and iI'm curious of 3 things...
1. How many gallons of gasoline does my car hold? is it 11 or 12? Just curious for my MPG. Search on google for "1996 del sol specs". You'll find your answer. To save you the time, it's 11.9 gallons
2. How many quarts of oil does my engine take? Isn't it 4? I just did a change and I'm a just below the lower dot on my dipstick after putting four quarts in.Search on google for "1996 del sol specs". You'll find your answer. however, you should just fill your del sol up with ~3.5 quarts and then check the dip-stick after filling it up a bit more. Just keep checking til the dipstick levels are in the normal range.
3. I think I need to do a radiator flush, it smells like someone peed in the reservoir tank to the left of the radiator. Its so gross, besides its a little low. You should completely drain and replace with new coolant every 24 months. Use distilled water from your grocery store (buy a gallon, it's less than a buck) to flush out the coolant after it's all drained.
thanks </TD></TR></TABLE>
Modified by ke98248 at 1:09 PM 6/29/2007
Old Jun 30, 2007 | 08:58 PM
t@rzan's Avatar
AGREED
Old Jun 30, 2007 | 09:02 PM
deadline's Avatar
i think the owners manual will tell u all of these questions..........
Old Jun 30, 2007 | 10:14 PM
DCboosted95's Avatar
Default Re: (deadline)
I work at honda, and I believe that b series motors, minus the GSR, take 4.2 quarts to hit right at the full dot. the gsr has a bit bigger oil pan due to the girdle, but I'm sure most people on here know that
PICAR20
Feb 25, 2007 11:43 PM
GetawayInMoscow
Jul 6, 2005 09:59 AM
projecteg2
Sep 23, 2004 04:06 PM
jdmwidebody094
Nov 11, 2003 12:46 PM
RatedX
Aug 27, 2003 12:33 PM
