ITB's? Are they worth it?
I am lookin at buying a set of ITB's from Toda or TWM but I dont know anyone that has used them for a street/strip application. I was wondering what I would have to do to make sure that my teg runs good and i need to kno if its even worth it. Would it be better to get a different intake manifold like Skunk2? I need to kno the ups and downs so I can figure out if I want to spend the $1500-$2500 for the setup. Everything is almost done with the motor. Block is built, 13:1 comp, head is milled completely, valves retainers and springs, Skunk2 stage 3 cams. I just wnat to most possible flow. Is it worth it?
Definitely. Couple that **** with a race header and you're SET!
How much of a gain did you see with the Stage 3 Cams? Cuz I plan to put Stage 2 in mine, with a P&P, honing etc. And I want to run TWM ITB's and Toda RH.
Good luck!
Good luck!
97CTR
23
Jan 29, 2004 07:09 PM
b16powwer
Oct 23, 2002 09:16 PM
