Compression Ratio's
I need some help. i am wanting to use CTR pistons in my gsr block. i have stock gsr rods/crank and a b16 head with stock cams. i was wanting to know about what compression ratio would that put me at. I have read everything from 11.1:1 all the way up to 12.5:1 so any info that you have will be very helpful. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 »</TD></TR><TR><TD CLASS="quote"> http://www.zealautowerks.com/
This should help you out. </TD></TR></TABLE>
X2 thats a good website
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM se-R »</TD></TR><TR><TD CLASS="quote">doesn't the highst octane rating for pump gas only go up to 91? Isn't it 87, 89, and 91 octane at the pumps?</TD></TR></TABLE>
yes, in CA... i believe they have 93 pumps in other states and countries... but i've seen 100 pumps at some 76 stations here in CA
correct me if i'm wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I heart My EF Sedan »</TD></TR><TR><TD CLASS="quote">yes, in CA... i believe they have 93 pumps in other states and countries... but i've seen 100 pumps at some 76 stations here in CA
correct me if i'm wrong</TD></TR></TABLE>there is 100 octain pumps around here.but they say race gas on them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11KRedline »</TD></TR><TR><TD CLASS="quote">wow- that gave me 12.74 to 1 and that is without the head or block being shaved. what is the highest that you can run with 93 oct pump gas?</TD></TR></TABLE>
You can run that on pump. You'll have to pull timing though. So i would recommend two tunes then. One on 93 and one on race gas, so when you race you can have the most out of the high compression.
i appreciate all the info. i think i will use the ctr pistons and then try the 2 different tunes. also in order to run that kinda compression efficently and get the max performance - is there any major thing else that yall might recomend me use (etc. ignition, exhaust size- anything at all)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch »</TD></TR><TR><TD CLASS="quote">love the eastcoast for 93 octane</TD></TR></TABLE> damn right
for the OP ive found that website to a little on the high side with their calculator. You can always adjust comression through the headgasket as well
This is actually what you want to look at...searching the archives is amazing isn't it?
https://honda-tech.com/zero...ge=11
Check back on the very first page of this thread link and you'll see that you're looking at about 12.58:1 compression.
If your planning on running 12:1 compression ratio it is advisable to get retuned on season change like winter->summer and vise versa to make sure your tune is reliable and not pinging. Fuel also changes in the winter which is a big deal.
Lucky bastards.
Lucky bastards.
umm how about octane booster + 91 octane can u use that with high compression? hahah
and for the guy who said u have to "pull timing" to make it run right.. what do u meen the cam gears? or the distributer thing?!
kantfadedisazn
21
Sep 17, 2006 11:10 PM
norcalbayboy
29
Aug 7, 2006 10:08 PM
Nerologic
Apr 22, 2006 07:15 AM
christhereefer
18
Dec 28, 2005 06:11 AM
