TYPE R THROTTLE BODY REPLACEMENT
I have a bad tps sensor and i found out that the tps sensor is irreplacable.
Im wondering if EDELBROCK throttle body would be a good replacement.
Its $300 for the edelbrock and about $600 for the oem type r tb.
Anyone here have experienced the edelbrock tb before? is there another
fitment besides the edelbrock with the tps attached?..like other b-series
tb?
tb?
tps is replaceable now
https://www.kingmotorsports.co...t_780
http://inlinefour.com/il4oemretps.html
Before he asks:
To remove the rivets from the TPS, simply dremel/file a slit into the rivet end, turning it into a flat head screw (As the rivets, aren't really rivets, they're screws with rivited ends), now just screw them out, and replace them with 10mm screws. Set proper voltage, and voila.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjgerolaga »</TD></TR><TR><TD CLASS="quote">dont waste your money on edelbrock. wants something cheaper and 80 mm. infinity Q45 throttle body.
with minor mods still less than 100 bucks. </TD></TR></TABLE>Do you mind to collaborate more on your so call "with minor mods"?
does the q45 tb bolt right on? what mods do you have to make? 80mm is huge! are there any adverse effects with running something that large?
with minor mods still less than 100 bucks. </TD></TR></TABLE>does the q45 tb bolt right on? what mods do you have to make? 80mm is huge! are there any adverse effects with running something that large?
