what r we missing trying to make 220 whp on a 1.8L?
Old Jun 28, 2007 | 07:51 PM
rev-speed's Avatar
Default what r we missing trying to make 220 whp on a 1.8L?
Ok about a year ago i made 208whp on my 1.8l
with a stock head(stock port work)
-june 2
-with more time on the dyno i could have pulled out another 2-3whp
-my old setup 208whp
[IMG] http://img112.imageshack.us/im...t.jpg [/IMG]
a few weeks ago we just finish my buddys car
we ended up makeing only 200whp.....(we were sure we would make at least 215whp)
what the hell!!!
-he has a portflow ported head
-skunk2 stg2 cams
my buddys set up 200whp
thanks 4 looking
Modified by rev-speed at 5:05 PM 7/9/2007
Modified by rev-speed at 5:07 PM 7/9/2007
Modified by rev-speed at 5:09 PM 7/9/2007
Modified by rev-speed at 5:10 PM 7/9/2007
Modified by rev-speed at 5:16 PM 7/9/2007
Modified by rev-speed at 5:17 PM 7/9/2007
Old Jun 28, 2007 | 10:06 PM
mtber's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (rev-speed)
Making 200+ whp on a 1.8L platform is a lot harder then people think.
A lot of the reason people think it is easy to do is due to the dynapack numbers introduced to them on honda-tech.
Old Jun 28, 2007 | 11:43 PM
MikeSarr_GSR's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (mtber)
which JG intake manifold were you running on the 208 setup?
also, what was your reasoning behind using 550cc injectors on that
motor that made 200 -
Old Jun 29, 2007 | 02:30 AM
OC Geezer's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (MikeSarr_GSR)
What else does his motor have?
Old Jun 29, 2007 | 03:32 AM
b19coupe's Avatar
Making 220 whp with a 1.8 liter motor requires the exact right combination of parts. Starting with a good intake, a better than stock intake manifold, a very good head with the right cams properly timed, a good header and exhaust. + lots of tuning. Not to mention a well put together bottom end.
Old Jun 29, 2007 | 01:15 PM
fergy016's Avatar
Port matched intake manifold to head? What header? What exhaust piping diameter are you running? What throttle body size? What is the static compression ratio? Intake restrictive at all? Intake intalled, I have heard filter on throttle body you loose power.
Old Jun 29, 2007 | 02:42 PM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">which JG intake manifold were you running on the 208 setup?
</TD></TR></TABLE>the bigger old one
motor that made 200 -</TD></TR></TABLE>
(price)we got the 550cc cheap
Old Jun 29, 2007 | 02:45 PM
94typeR's Avatar
im hoping to break 200whp without touching the port of the head and keeping the block bone stock.
Old Jun 29, 2007 | 02:47 PM
rev-speed's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (InLtegSra94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLtegSra94 &raquo;</TD></TR><TR><TD CLASS="quote">What else does his motor have? </TD></TR></TABLE>
-b16 head (portflow)
blox intake manifold (portmatch and ported not cut open)
portflow valve spring and retainers
stock valve (type r)
sk2 stg2 cams
-block
b18a
ptc pistons
-550 rc injectors
-91 octane
-and major tuning
Old Jun 29, 2007 | 02:55 PM
rev-speed's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Making 220 whp with a 1.8 liter motor requires the exact right combination of parts. Starting with a good intake, a better than stock intake manifold, a very good head with the right cams properly timed, a good header and exhaust. + lots of tuning. Not to mention a well put together bottom end.</TD></TR></TABLE>
what combo do u suggest?
Old Jun 29, 2007 | 03:23 PM
rev-speed's Avatar
Default Re: (fergy016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">Port matched intake manifold to head? </TD></TR></TABLE>
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote"> What header? What exhaust piping diameter are you running? </TD></TR></TABLE>highend motorsport /dyno on open headers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote"> What throttle body size? What is the static compression ratio? Intake restrictive at all? </TD></TR></TABLE>
68mm on the 208whp
60mm on the 200whp
13.6-13.8-1
Old Jun 29, 2007 | 03:33 PM
DonF's Avatar
Default Re: (rev-speed)
Crank scraper? Proper oil drain tubes? Correct side rod clearances? Correct ring end gaps? Proper bearing clearances? They all add up.
Old Jun 29, 2007 | 04:32 PM
hybrid_KJ's Avatar
Default Re: (DonF)
Don,
There is a guy near me that makes crank scrapers for alot of engines including Honda engines. I provided him with some Honda, vw and bmw engines for him to design around. He mentioned that you had done some testing and saw a couple percent gain throughout the rpm range on n/a b series stuff. Any truth to this?
Old Jun 29, 2007 | 08:49 PM
rev-speed's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Crank scraper? </TD></TR></TABLE>
no crank scrapers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Proper oil drain tubes? </TD></TR></TABLE>
opened up all drain casting on the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Correct side rod clearances? Correct ring end gaps? Proper bearing clearances? They all add up.</TD></TR></TABLE>
on both motors rod side clearance .003-.005
ring gap top ring .015 second ring .017
main and rods .015-.017
i know u might not want to give up ur clearanc secrets but am i around the rite track?
Old Jun 29, 2007 | 09:14 PM
MikeySpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">Ok about a year ago i made 208whp on my 1.8l
-<U>june 2</U>-with more time on the dyno i could have pulled out another 2-3whp
http://www.mercedimports.com/p...40251
Was that the cam used, or the date of the dyno?
Old Jun 29, 2007 | 09:31 PM
rev-speed's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (MikeySpec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">
Was that the cam used, or the date of the dyno? </TD></TR></TABLE>
yes the cams used
it was pulled off of a race car that made 224 whp same dyno
motor is a 86x87@i say around 11.5-1 compression
Old Jun 30, 2007 | 03:27 PM
DonF's Avatar
Default Re: (hybrid_KJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_KJ &raquo;</TD></TR><TR><TD CLASS="quote">Don,
There is a guy near me that makes crank scrapers for alot of engines including Honda engines. I provided him with some Honda, vw and bmw engines for him to design around. He mentioned that you had done some testing and saw a couple percent gain throughout the rpm range on n/a b series stuff. Any truth to this?</TD></TR></TABLE> Yes, there stuff works, I supplied some other blocks. I really like the new teflon scrapers.
Old Jun 30, 2007 | 07:53 PM
zexxbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rev-speed &raquo;</TD></TR><TR><TD CLASS="quote">what combo do u suggest?</TD></TR></TABLE>
whale ***** intake..
smsp/hytech headers..
2.5"-2.75" exhaust piping..
s2pro2 or s2s3 cams..
an oil change..
and maybe some 100 octane..
you said your ptc pistons are netting 13.5ish cr?
Old Jun 30, 2007 | 09:13 PM
xD**ktonesx's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Yes, there stuff works, I supplied some other blocks. I really like the new teflon scrapers.</TD></TR></TABLE>
had a teflon scraper on my VR6
Old Jul 1, 2007 | 10:24 AM
sa90eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Making 200+ whp on a 1.8L platform is a lot harder then people think.
x2
good luck on your 220whp quest
put some toda D and rev it to 11K
Old Jul 1, 2007 | 10:26 AM
DA_JDM's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (sa90eg)
Its hard to get to 220whp...i was dissapointed with my 215WHP on a mustang dyno but now i know that those are healty numbers 220WHP on a dynapack is less harder to obtain people are telling me!!!
Old Jul 1, 2007 | 12:29 PM
Combustion Contraption's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (DA_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">Its hard to get to 220whp...i was dissapointed with my 215WHP on a mustang dyno but now i know that those are healty numbers 220WHP on a dynapack is less harder to obtain people are telling me!!!</TD></TR></TABLE>
depends which dynapack.
b19coupe, who has posted in this thread used to have a 1.8 that made 22x at R&D if i recall correctly.
Old Jul 1, 2007 | 08:45 PM
drewbie's Avatar
-june 2
what the hell!!!
-skunk2 stg2 cams
http://www.mercedimports.com/p...=4951
thanks 4 looking
I know someone who made 226 whp on a 1.8
Old Jul 2, 2007 | 10:31 AM
rev-speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">Its hard to get to 220whp...i was dissapointed with my 215WHP on a mustang dyno but now i know that those are healty numbers</TD></TR></TABLE>
was this on a 1.8l?
Old Jul 2, 2007 | 10:32 AM
rev-speed's Avatar
Default Re: what r we missing trying to make 220 whp on a 1.8L? (drewbie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewbie &raquo;</TD></TR><TR><TD CLASS="quote">
I know someone who made 226 whp on a 1.8</TD></TR></TABLE>
who?
