B16 ignition timimg
Old Jun 28, 2007 | 07:05 PM
B16A CRX's Avatar
Default B16 ignition timimg
any help would be nice im running a B16 with 82 mm CTR's i think the compression is around 12:1. the motor is completely built and I need to know how to set the dizzy timing. The motor will be tuned later but i need a safe timing to run for a couple of miles until motor is completely broken in. Thanks in advance.
Old Jun 28, 2007 | 07:10 PM
mtber's Avatar
Default Re: B16 ignition timimg (B16A CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">any help would be nice im running a B16 with 82 mm CTR's i think the compression is around 12:1. the motor is completely built and I need to know how to set the dizzy timing. The motor will be tuned later but i need a safe timing to run for a couple of miles until motor is completely broken in. Thanks in advance.</TD></TR></TABLE>
This all depends on what ecu map your running :-)
You will be able to hear audible detonation at partial throttle.
Shoot the timing to factory 16.5 deg btdc & just stay out of a wide open throttle condition.
Old Jun 29, 2007 | 02:44 AM
Richard...'s Avatar
Default Re: B16 ignition timimg (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Shoot the timing to factory 16.5 deg btdc & just stay out of a wide open throttle condition.</TD></TR></TABLE>
i thought factory was 16 deg
to be on the safe side i would set the timing to 14 deg
Old Jun 29, 2007 | 12:02 PM
B16A CRX's Avatar
I have a p28 with a B16 basemap and i will be using 93 pump gas.
Old Jun 29, 2007 | 02:24 PM
Richard...'s Avatar
Default Re: (B16A CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">I have a p28 with a B16 basemap and i will be using 93 pump gas. </TD></TR></TABLE>
oh **** will you did not say that then you will be fine!
Old Jun 29, 2007 | 07:26 PM
B16A CRX's Avatar
Default Re: (richard7968)
ok but what and how do i set the timing. i have the timing gun
Old Jun 29, 2007 | 10:12 PM
H9Omega's Avatar
http://www.c-speedracing.com/h...g.php
the_dxB16
Sep 25, 2009 07:38 AM
See Are X
May 26, 2006 08:09 PM
S@nt0s
36
Oct 14, 2005 07:02 PM
SpeedMonkeyRacing
Nov 11, 2002 05:37 PM
