crankshaft pulley removal Help!!!!
Old Jun 28, 2007 | 03:37 PM
290allen's Avatar
Default crankshaft pulley removal Help!!!!
first question is how are most people getting this off, and second question, is it regularly threaded or reverse threaded? thanks in advance.
Old Jun 28, 2007 | 03:51 PM
hondacivic90zc's Avatar
Default Re: crankshaft pulley removal Help!!!! (290allen)
it is regular threaded
Old Jun 28, 2007 | 03:57 PM
yz125rider21's Avatar
man power!!!
Old Jun 28, 2007 | 04:11 PM
290allen's Avatar
Default Re: crankshaft pulley removal Help!!!! (iandavis90)
thanks i figured it was but i wanted to make sure.
Old Jun 28, 2007 | 04:22 PM
regular thread but better get a big pipe or a big breaker bar cause its on there TIGHT
Old Jun 28, 2007 | 04:23 PM
Bjorn20's Avatar
get a decent size impact with a compressor that can handle it and whale on it.
remember.... doesnt matter how much torque your air tools can do if you have a shitty compressor
either that or get creative to rig something up to keep the flywheel from moving and get a huge breaker bar along with a big pipe/cheater bar/ if needed and give it everything you got. If the engine is out of the bay, its best to have another person hold the motor.
Old Jun 28, 2007 | 04:32 PM
Default Re: crankshaft pulley removal Help!!!! (Bjorn20)
when i took it off of my sohc zc the motor was on an engine stand with a huge screwdriver pried on the flywheel bolts and the stand. It took a 1/2 inch drive breaker bar and a jack handle to break it lose and that was after bending a couple craftsmen screwdrivers.
Old Jun 28, 2007 | 05:47 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">get a decent size impact with a compressor that can handle it and whale on it.
Also,make sure the socket you use is a six-point and fits the bolt tightly..
If it has play,the force of the impact is lost...
Old Jun 28, 2007 | 06:31 PM
pepper's Avatar
2 five foot pipes
Old Jun 29, 2007 | 06:38 AM
Boosted_CRX_507's Avatar
Default Re: (pepper)
if ur motor is still in the car get a big wrench and a breaker bar and lock it to the ground and go hit start wiht your key...it should break it loose
Old Jun 29, 2007 | 07:59 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (Boosted_CRX_507)
http://home.earthlink.net/~honda.lioness/id6.html
Old Jun 29, 2007 | 08:32 AM
290allen's Avatar
Default Re: (HondaPartsHero)
well i actually ended up making one of those tools last night before i saw that, still nothing got the motor in my bros truck so i can swing it by a place that has a better air wrench then me.
Old Jun 29, 2007 | 09:31 AM
mra4886's Avatar
Default Re: (290allen)
best way i found to do it is just jack the driver side up. put the tranny is 5th gear. have someone hold the break and you use all your force on a breaker bar to break it loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_CRX_507 &raquo;</TD></TR><TR><TD CLASS="quote">if ur motor is still in the car get a big wrench and a breaker bar and lock it to the ground and go hit start wiht your key...it should break it loose </TD></TR></TABLE>
ive though about that the other day and was wondering if that would work if the motor would spin the way to break it loose.
Old Jun 30, 2007 | 06:52 AM
KrazyK_20's Avatar
Default Re: (mra4886)
IMPACT WORKDS THE BEST. DONT WASTE YOU TIME TRYING TO BREAK IT LOOSE BY HAND
Old Jun 30, 2007 | 07:05 AM
90crxdriver's Avatar
Default Re:
I've went at it for two days now with a impact gun and nothing. I'm going to get a long extension and a long pipe and see if that works. I'm about ready to take it to a shop and pay to get it removed. I really got to replace my timming belt soon.
Old Jun 30, 2007 | 07:38 AM
george34's Avatar
Default Re: Re: (90crxdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdriver &raquo;</TD></TR><TR><TD CLASS="quote">I've went at it for two days now with a impact gun and nothing. I'm going to get a long extension and a long pipe and see if that works. I'm about ready to take it to a shop and pay to get it removed. I really got to replace my timming belt soon.</TD></TR></TABLE>
I spent ~4 hrs. trying to get mine out with an impact gun. I finally decided to take to a shop with bigger equipment and they had it off within a minute. I say take to a shop if you have already tried for a couple hours.
Old Jun 30, 2007 | 07:45 AM
HondaHeddie's Avatar
Default Re: Re: (george34)
I used my 240lb/ft impact and could not budge it.
I ened up taking it to a shop for them to hit it with their big mama impact wrench. Even then they said it was tight.
From what I have heard you are less likely to damage the shaft if you impact it off instead of muscling it
Old Jun 30, 2007 | 08:09 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: Re: (HondaHeddie)
you people need stronger impacts
Old Jun 30, 2007 | 09:49 AM
99teggsr's Avatar
Default Re: Re: (ILcrxsi1)
to get mine off I used a 3 foot breaker bar and stood on the bar and jumped on it a little and it broke loose. Get someone who is really fat to stand on the bar
Old Nov 30, 2008 | 11:31 PM
xxfile's Avatar
for people who got it off by impact gun, what size of impact gun are you guys using? I mean how many ft-lbs?
Old Dec 1, 2008 | 12:03 AM
D16SiHatch's Avatar
you need a chain wrench. it will be your friend
i used this, a shop rag around the crank, and a 2 foot steel pipe on the end of a 3/4" ratchet to break the bolt loose. i would of used a larger pipe for leverage but its all i had. even with the small pipe i still had it off in no time at all. i've used this method a few times now and its worked everytime. 250ft/lb impact wasn't nearly enough to make it budge in the slightest.
Old Dec 1, 2008 | 07:10 AM
xxfile's Avatar
I still don't understand how does this chain wrench help you...
My impact gun is 275 ft/lbs, so... probably not enough?
Old Dec 1, 2008 | 11:33 AM
D16SiHatch's Avatar
you wrap the wrench around the crank to hold it stationary, and set it against the floor to use it as leverage.
Old Dec 1, 2008 | 11:41 AM
d16man's Avatar
never put a screw driver in the one of the holes and stop it from spinning with the lip of the oil pan unless u plan on not usen that oil pan! just wanted to let u kno
Old Dec 1, 2008 | 11:48 AM
jdmed3's Avatar
there is a special tool that is octogonal shaped and its hollow so you can fit an impact in there to get it you just put a breaker bar on the handle and hold it on the floor
