ls cam retainer torque specs??????
Old Jun 28, 2007 | 02:28 PM
vtec killin's Avatar
Default ls cam retainer torque specs??????
im about to put in some crower 402's. i was wondering how much do i torque the things that hold the cams down? also i was wondering how much to torque the cam gear? coud u help thanks.
91 teg rs
Old Jun 28, 2007 | 05:29 PM
Madness's Avatar
Default Re: ls cam retainer torque specs?????? (vtec killin)
I was wondering why you'd do a cam swap without a Helms manual. PM'd.
Old Jun 28, 2007 | 06:58 PM
Sam92Teg's Avatar
On the LS engines, only torque the cam caps to 7 lb/ft of torque, thats not much. The VTEC engines use higher torque specs.
The cam gears are 27 lb/ft of torque.
You probably already know to use oil or assembly lube and to break the cams in for 20 minutes after install. Also, loosen the rocker arms before the install because your Crowers will have higher lift specs and could cause them to bind during installation. Then adjust the valves to spec.
intake valves .003 - .005 inches
exhaust .006 - .008 inches
Let us know how she runs when all is said and done.
Old Jun 29, 2007 | 12:05 AM
Default Re: ls cam retainer torque specs?????? (Sam92Teg)
thanks guys she runs lika champ you can deffinatly tell a diffrence even at idle! it was my first time doing the swap and i did it by my self. i think i did good for being only 16. ima test run it a little more tommarow and im pickin up cam gears so that will show a improvment to.
Old Jun 29, 2007 | 12:25 PM
urrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!
ok so this morning i was taking off the timing belt and i marked and set it at tdc and took off the belt. then i put it back together and put it back at the same place [or so i think] and tried to start it. all it did was turn over. i smell gas also? could it be the timming off? it looks to me like its straight on but idk please helllp???
bustdgst
Oct 18, 2006 12:01 PM
boosted k20
Dec 5, 2004 12:41 PM
Darkane
Jul 27, 2004 08:46 PM
snake01
May 9, 2003 05:32 PM
Cornershop
Dec 3, 2002 03:52 PM
