90 integra won't fire
Old Jun 28, 2007 | 01:37 PM
FrOsTwHiTeDC4's Avatar
Default 90 integra won't fire
My friends 90 integra won't start. It is a jdm b20 and still obd0. He changed the cap and rotor and the plugs and wires look fine. We also checked out all the grounds but it still won't start. It is getting fuel but just not spark. Anyone have any idea's on what might be going on?
TIA
Albert
Old Jun 28, 2007 | 01:41 PM
blueDA9's Avatar
it might possibly be the main relay or the igniter....my 91 used to have that problem til i changed the igniter...so try that
Old Jun 28, 2007 | 05:22 PM
Default Re: (blueDA9)
car is also throwing code 8 if that means anything.
Old Jun 28, 2007 | 05:26 PM
spada's Avatar
Default Re: (FrOsTwHiTeDC4)
http://www.c-speedracing.com/faq/05.php
Could be the TDC sensor
Mine is doing the same, less the engine code, so I am stumped as hell
Old Jun 28, 2007 | 08:04 PM
GSR-TRBO-DA's Avatar
Default Re: 90 integra won't fire (FrOsTwHiTeDC4)
my da is doing almost the same thing. have you already checked the dizzy? how about your main relay? does your fuel get to the fuel rail? where did you check if you had fuel from? did you use the dizzy from the b20 or ur original motor or another motor altogether?
Old Jun 30, 2007 | 03:16 PM
Default Re: 90 integra won't fire (GSR-TRBO-DA)
it was the dizzy...it was using the dizzy from the stock motor and i swapped it and now it runs mint.
ascarberry
Mar 27, 2013 12:02 AM
LiL JoN
Jun 26, 2010 09:58 AM
90goldhatch
Sep 11, 2009 04:48 PM
hex_04
Feb 6, 2008 04:15 PM
Master23
Aug 1, 2004 08:16 PM
