NEED HELP WITH FLUIDYNE 94-01 RADIATOR WITH FLEX - A- LITE FAN
alright guys ran into a problem :
i bought a fluidyne radiator and a fal fan ( dual fan )
went to mount this thing and the brackets dont fit.
i know back in the day they used to make them . i called both companys and fal told me they used to make a bracket to mount the slim fans on to the fluidyene.
but not any more ............ so if any of you guys have this combo can you please help me on this........ maybe show some pics how you mounted it . anything. thanks
http://www.modacar.com/Merchan...2.jpg
this is the fan i bought ^^^^^
You might want to take some rough measurements to make sure it will fit before modifying it.
FYI, I know for a fact that combo will not work with the Toda or Spoon header with a/c. The a/c line that runs between the two fans will rest on the header. I just got 2 Maradyne 10" slim fans and could not be happier... plus they sound ultra cool. (Vote for me ROTY 08)
Not sure if these will be helpful to you:
Koyo is the same size as the Fluidyne I think. The Header is a HiTech
I think my shop had to fab one of the mounts from scratch to make it fit
I love how close these aftermarket fans sit to the header.
How long have you had the above setup?
Considering the stock rad is half the thickness - it's a wonder the FAL fan fits at all.
I've had this setup for almost a year.
The header is ceramic coated to reduce heat - which helps from melting the FAL fan.
Draggin99Si
Feb 7, 2007 05:15 PM
