LS w/ GSR crank
Old Jun 28, 2007 | 09:32 AM
bnut510's Avatar
Default LS w/ GSR crank
this might be a dumb question to ask but... if u have a ls block with a gsr crank... would that be considered pretty much a gsr block without the oil squirters?
another question, what belt sizes should i run with this setup? im totally lost on this one. this is my first real build from the ground up, so im still learning all the technical stuff.
Modified by bnut510 at 8:51 AM 7/2/2007
Old Jun 28, 2007 | 10:59 AM
2ltrtodd's Avatar
* B A N N E D *
no. it will still have lower compression than a gsr. unless you swap pistons also.
Old Jun 28, 2007 | 03:24 PM
bnut510's Avatar
Default Re: (2ltrtodd)
pistons are swapped to a 25. overbore type r pistons with a b16 head with type r valvetrain.
Old Jun 28, 2007 | 04:02 PM
pr0honda's Avatar
Default Re: (bnut510)
the displacement will be same as gsr but the block itself is not as strong. it will work fine though.
shawn
Old Jun 28, 2007 | 04:20 PM
bnut510's Avatar
Default Re: (pr0honda)
interesting.. i also thought of this... but what is the reason that the ls block isnt as strong as the gsr block? just curious cuz this its what i am working with right now. its basically a bunch of spare parts i had lying around, and i threw pieces together to complete this motor as pretty much a backup.
Old Jun 28, 2007 | 06:55 PM
Dateggy21's Avatar
It is an odd setup, although it can be very powerful. It is in no way weaker than a GSR block, same thing, get a stock gsr block girdle or after market one, and just check all your clearences, you will be good to go.
Old Jun 29, 2007 | 10:43 AM
bnut510's Avatar
Default Re: (Dateggy21)
i got everything back form the machine shop already.. they did a full job on it.. hone, decked, valve job, micropolished crank, bla bla bla... i was just wondering what i had really lol. i know its an odd build but i am using whatever spare parts i had laying around on this setup. anyone else with some input?
Old Jun 30, 2007 | 02:09 PM
pr0honda's Avatar
if you compare the blocks next to each other you will see that the gsr block has more braces through out.
as i said the ls block will work fine. i was just listing difference between the 2. they are not the same.
shawn
Old Jun 30, 2007 | 10:46 PM
Broken Gearbox's Avatar
which rods are you running?
Old Jul 2, 2007 | 07:49 AM
bnut510's Avatar
Default Re: (Broken Gearbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Broken Gearbox &raquo;</TD></TR><TR><TD CLASS="quote">which rods are you running?</TD></TR></TABLE>
i gave my machine shop guy a bunch of rods that were already out the car. i baught a block with a bunch of misc parts from a friend of a friend. anyways it was a bunch of **** in there and i told him to just make it happen. but frm what i remember im gonna say ls rods. just some stockies, i figure its just gonna be pretty much stock so itll be ok.
btw, anyone know what belt sizes i should be using with this weird setup? i edited my first post asking about this as well. thanks for the help
Old Jul 2, 2007 | 08:11 AM
Chris Tune's Avatar
if u use gsr crank u need gsr rods... and your compression will even be higher than a stock b18c or b18a with the 89mm crank... trust me on this... i KNOW what im saying from first hand experience
Old Jul 2, 2007 | 08:15 AM
bnut510's Avatar
Default Re: (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">if u use gsr crank u need gsr rods... and your compression will even be higher than a stock b18c or b18a with the 89mm crank... trust me on this... i KNOW what im saying from first hand experience </TD></TR></TABLE>
u could be right, i wasnt sure to be honest. yea i know dummy move.. anyways, any help with the timing belt size? its also with a gsr water pump.
Old Jul 2, 2007 | 08:45 AM
Chris Tune's Avatar
gsr water pump use a gsr belt... LS will be too small... i havent seen it that way... i have seen LS water pump gsr belt, with the belt adjustment all the way its still HELL loose...
Old Jul 2, 2007 | 08:54 AM
bnut510's Avatar
thx man, thanx for replying on both my posts lol. do u know about the tq specs for the lower rod connect that connects to the crankshaft? im asking this because i had took the gsr oil pan out and seen that the pick up was connected to this big piece of alum. (wish i knew the term). i dont want the motor falling apart on me. i keep having dreams of disaster lol.
Old Jul 2, 2007 | 09:00 AM
Chris Tune's Avatar
the "thing" that connects the 3 main center caps on the crankshaft?
Old Jul 2, 2007 | 09:06 AM
bnut510's Avatar
the lower piece of the rod. that half round piece. i guess that would be the tq specs for a rod then? i think?
Old Jul 2, 2007 | 09:10 AM
pr0honda's Avatar
89mm crank will have higher compression than a 87mm crank if you are using the same pistons.
you can notice this when you look at a b16a piston its dome is larger than a piston for a 1.8ltr to equal same compression. as you increase the displacement you dont need as much of a dome.. unless of course u want much higher compression.
shawn
Chris Tune's Avatar
per oem specs if it has stock rod bolts it goes in 2 steps...
1st 14ft-lb
2nd 33ft-lb... use some type of moly lubricant or 10-30 oil on the threads...
or if u know how to stretch the rod bolts 0.13 - 0.15 mm
Old Jul 2, 2007 | 09:20 AM
Chris Tune's Avatar
depends on which block ure using
Old Jul 2, 2007 | 09:29 AM
pr0honda's Avatar
explain your theory. the concept is the same regardless of what block youre using.
Old Jul 2, 2007 | 09:41 AM
Chris Tune's Avatar
not a theory...
all the block i have done LS block gsr/R cranks rods the pistons STICK out the block.. .020 is kinda norm in there... with the pistons residing in the block with LS crank u got more compression with the GSR crank in LS block... even thou i have done all but a few but they all showed the same tendency. .015 - .020+ out the hole... and the same block with LS crank rods they come close to -.018 - .020 IN the hole...
Old Jul 2, 2007 | 09:47 AM
bnut510's Avatar
pistons are itr pistons .25mm over if that makes a difference
vpower101
Jan 21, 2008 10:47 AM
mymeatb18"
Jun 26, 2006 03:16 PM
SwappedTURBOegg
Sep 13, 2005 04:55 PM
slowassgsxr750
Jun 30, 2003 08:36 PM
EK Hybrid
Apr 24, 2003 03:35 AM
