question on compression
Old Jun 28, 2007 | 08:48 AM
Mr.EGo's Avatar
Default question on compression
Can somebody explain to me what a compression is and what those numbers mean ex. 13:1? i dnt know much yet and i tried searching it on HT and i cant really find an answer to my question. Thnks
Old Jun 28, 2007 | 09:03 AM
TooManyTickets's Avatar
Default Re: question on compression (ocnarF0303)
http://auto.howstuffworks.com/engine1.htm
That site has alot of other usefull info as well, and its all broken down
To learn what compression is i highly advise you to learn the 4 stroke cycle of intake, compression, power, and exhaust
Old Jun 28, 2007 | 10:30 AM
Default Re: question on compression (TooManyTickets)
In the animation above you will see the piston travle from the bottom to the top of the cylinder. lets say our engine has 1.6L now we divide that by 4 cylinders, and we get about 400cc per cylinder(keep in mind that this is the volume available in the cylinder at whats called Bottom dead center, the bottom of the pistons travel)... now if you were to measure out the volume available in whats called the combustion chamber, at the top of the cylinder( or Top dead center). you will get a compression figure.
400cc per cyl
lets say 9:1 compression ration... now whats 1/9 of 400?
400\9= 44.444
so the combustion chamber size is roughly 44.444cc of volume
and the piston has squeezed the air fuel mixture down to 1/9 of its original size since it was drawn in at the intake stroke
Old Jun 28, 2007 | 10:49 AM
Mr.EGo's Avatar
thnks...that was a good site has a lot of info....
Old Jun 28, 2007 | 01:20 PM
b20beast978's Avatar
good link very helpful
EastSideRacer
K Series
Mar 24, 2010 06:49 PM
Dave_Dc2
Nov 3, 2008 06:29 PM
JDean6pac
Apr 10, 2007 09:01 PM
Bcuz
Mar 16, 2005 03:24 PM
RiCE On IcE 2
Jul 29, 2002 02:15 PM
