JDM gsr & USDM type r bottom ends the same?
Old Jun 28, 2007 | 08:46 AM
jdmland's Avatar
Default JDM gsr & USDM type r bottom ends the same?
I understand they have the same pistons etc. different heads, but does the bottom end of the jdm gsr come with the pistons top coated from the factory like the usdm type r's? rods lighter? lighter crank?
if they did just stick in type r pistons in the gsr bottom end, did they come top coated ? Searched, found they are the same compression bottom ends but thats all i have found.
Old Jun 28, 2007 | 09:01 AM
nutsack's Avatar
Default Re: JDM gsr & USDM type r bottom ends the same? (jdmland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmland &raquo;</TD></TR><TR><TD CLASS="quote">I understand they have the same pistons etc. different heads, but does the bottom end of the jdm gsr come with the pistons top coated from the factory like the usdm type r's? rods lighter? lighter crank?
if they did just stick in type r pistons in the gsr bottom end, did they come top coated ? Searched, found they are the same compression bottom ends but thats all i have found.</TD></TR></TABLE>
they have the same block. the rods, pistons, and crank are P73 (type R) specific. type R piston skirts are molybdenum coated, gsr are not. the type r crank has more counterweights than a gsr crank.
Old Jun 28, 2007 | 12:02 PM
jdmland's Avatar
Default Re: JDM gsr & USDM type r bottom ends the same? (*******)
i had to ask, cause this is what i found, and says they are the same
B18C1 = Integra GS-R (USDM)
B18C2 = Integra Vtir (AUDM)
B18C3 = Integra Type R (96-97)(JDM)
B18C4 = Civic 1.8 Vti (EDM) ---aka spoon
B18C5 = Integra Type R (USDM)
B18C6 = Integra Type R (EDM)
B18C7 = Integra Type R (AUDM)
B18C: JDM Sir-G and ITR block
B18C1: US GSR block
B18C2: Australian GSR block
B18C3: Hong Kong/Taiwan GSR block
B18C4: European Civic
B18C5: US ITR block
B18C6: Euro ITR block
B18C7: Australian ITR block
Eg.ls.turbo
26
Sep 3, 2013 04:30 PM
95egGold
Aug 27, 2007 09:41 AM
RyosukeFC3s
Apr 30, 2006 08:48 AM
andre809_lude
Sep 1, 2005 12:54 AM
john_racer
Jan 25, 2005 12:27 PM
