d16y8 Crank Question?
Whats up H-T. Just span a bearing and the crank looks shot
. I need the car on the road soon.
I have d16y8 Block, from common sense i would say y7 crank would be the same but i'm not sure. If anyone was on this road before or know what crank i can use please help?
Thanks Vick
. I need the car on the road soon. I have d16y8 Block, from common sense i would say y7 crank would be the same but i'm not sure. If anyone was on this road before or know what crank i can use please help?
Thanks Vick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 »</TD></TR><TR><TD CLASS="quote">since i need to change the crank and they the same would u recommend the z6 one or it wouldn't make a difference?</TD></TR></TABLE>
z6 crank has chamfered oil holes on the crank journal, supposedly its for better lubrication purposes, check out my FS thread for pics of a z6 crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viskii420 »</TD></TR><TR><TD CLASS="quote">but since the oil pump is from y8 wouldn't make a difference?</TD></TR></TABLE>
its probably not recommended to use a z6 crank in a y8 along with a y8 oil pump.
the d16y motors are notorious for spun bearings..........now will the z6 oil pump work in a y8 block???? that i do not know....
alexsracing
Aug 29, 2005 09:10 PM
