important question
Old Jun 28, 2007 | 06:52 AM
civic46's Avatar
Default important question
hey all u honda civic guys.........wht year make and model did the dual cam zc motor come in with the 88-91 civics need to know as i have one in my race car and im wanting to prove the tech inspector guy wrong if i get caught with it.!
Old Jun 28, 2007 | 06:55 AM
DenzComp's Avatar
I "stole" this from a site when I googled DOHC ZC
What is a ZC?
1st gen DOHC ZC - brown valve cover - came in 86-87 JDM Integra - will bolt directly into 1st gen CRX Si and 3rd gen Civic Si - will not bolt directly into 2nd gen CRX or 4th gen Civic.
2nd gen DOHC ZC - black valve cover - came in 88-89 JDM Integra - will bolt directly into 1st gen CRX and 3rd gen Civic, same as brown valve cover, however, it uses electronic advance distributor like 88-89 USDM Integra D16A1 - 1st gen CRX Si and 3rd gen Civic Si have vacuum advance distributor, so, to use it on 1g CRX or 3g Civic, you will have to do a lot of wiring changes.
3rd gen DOHC ZC - black valve cover - came in 88-91 JDM CRX Si and Civic Si - bolts directly into 2nd gen CRX and 4th gen Civic.
4th gen DOHC ZC - black valve cover - came in several different models of JDM cars 92 & up - is OBD1 - has Cylinder Position Sensor inside the distributor and will bolt directly into 92-00 Civics
SOHC ZC - basically the same as D16A6 (little more horsepower) - will bolt directly into 2nd gen CRX and 4th gen Civic.
SOHC VTEC ZC - basically the same as D16Z6 - OBD1 - will bolt directly into 92-00 Civic
barney_SI
Dec 6, 2009 09:37 PM
b16er
Oct 20, 2006 07:05 PM
boomnn
Jul 2, 2006 08:35 PM
1badrex
18
Oct 10, 2003 07:23 AM
Ahknodd
May 1, 2003 07:47 AM
