Plug index kit how to use ?
Ive read the instructions does anyone have experience using this ?
http://static.summitracing.com...1.pdf
http://store.summitracing.com/...w=sku
i just dont understand what that thing u screw it into does exactly and what u ware marking on there because from the look of it u still have to mess with it in the cylinder ..correct ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">i just dont understand what that thing u screw it into does exactly and what u ware marking on there because from the look of it u still have to mess with it in the cylinder ..correct ? </TD></TR></TABLE>
The jig is not necessary to index the plugs. The plug indexing is done with the plugs in the head, and the jig is simply a way to index future replacement plugs (once you've determined the necessary shims and position) without having to spend time under the hood.
Crx Jimmy
Aug 2, 2008 08:07 AM
speedstash_com
Nov 8, 2005 05:57 AM
