Burnout Q.
Old Jun 27, 2007 | 11:37 PM
SoyMilk's Avatar
Default Burnout Q.
Going to the track.. does anyone know how to do a proper burnout to get good traction.
Old Jun 28, 2007 | 01:00 AM
Group Tenacity's Avatar
Default Re: Burnout Q. (l2al3l3it)
dont do it with street tires...
if you have slicks,
pull up so ur tires are just out of the water, hold the ebrake up, get the tire rpm up and wait for the slicks to start to pull you out of the water, then release the ebrake and stay in the gas for a sec. to get out of the water...
Old Jun 28, 2007 | 01:30 AM
94turboeg's Avatar
Default Re: Burnout Q. (Group Tenacity)
Third gear
Old Jun 28, 2007 | 02:12 AM
Default Re: Burnout Q. (94turboeg)
maybe thats why my 60' s suck, i been using 2nd
Old Jun 28, 2007 | 02:18 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">maybe thats why my 60' s suck, i been using 2nd </TD></TR></TABLE>
you are supposed to launch in 1st
Old Jun 28, 2007 | 02:21 AM
Default Re: Burnout Q. (dturbocivic)
i'll get this drag racing thing down one of these days...
Old Jun 28, 2007 | 01:09 PM
SoyMilk's Avatar
I only have streeet tires.
Old Jun 28, 2007 | 01:13 PM
94turboeg's Avatar
No burn out on street tires
Old Jun 28, 2007 | 01:33 PM
SoyMilk's Avatar
I have no slicks, what is wrong with using street tires at the track?
Old Jun 28, 2007 | 01:36 PM
raceACCORDingly's Avatar
nothing. but you dont burn out on street tires
Old Jun 28, 2007 | 01:45 PM
SoyMilk's Avatar
Default Re: (raceACCORDingly)
so I just drive skip the burnout part and go straight to the light?
Old Jun 28, 2007 | 01:54 PM
MrParks's Avatar
Default Re: (l2al3l3it)
in the drag racing forum there is a rule book thread. go in there and read the nhra rule book it tells you everything you need to safely and properly race down a drag strip
Old Jun 28, 2007 | 02:50 PM
Xtream_V's Avatar
Default Re: (MrParks)
sorry to thread jack but what about the falkens?
Old Jun 28, 2007 | 02:59 PM
SovXietday's Avatar
Default Re: (Xtream_V)
Street tires period, only thing you burnout with is drag radials and slicks.
Doing a burnout with regular street tires will cause them to be even more slick. Some tracks force you to go through the water, in that case you just want to "dust" them off persay, get them dry.
Old Jun 28, 2007 | 03:09 PM
Xtream_V's Avatar
Default Re: (SovXietday)
ok...so then our best bet would be to lower tire pressure right? is it best to work our way down or start lower and go up? whats a good psi to start at?
Old Jun 28, 2007 | 03:52 PM
T4 Neon's Avatar
35psi. You may need to make several reductions.
Old Jun 28, 2007 | 05:23 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (T4 Neon)
Why not do a burn out in 1st gear? Because you guys have a lot of power?
Old Jun 28, 2007 | 08:51 PM
sohc_vtec 2NR's Avatar
Default Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Why not do a burn out in 1st gear? Because you guys have a lot of power?</TD></TR></TABLE>
because first gear limits the wheel spin to only 33ish mph...whereas 2nd gear spins 50+mph
Old Jun 28, 2007 | 10:56 PM
realis9's Avatar
Default Re: (sohc_vtec 2NR)
In a ej1 making about 190 whp with drag radials what gear should i do a burn out in, and what rpm should i rev to make the tires spin?
Old Jun 28, 2007 | 11:18 PM
Quik Chris's Avatar
Default Re: (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">In a ej1 making about 190 whp with drag radials what gear should i do a burn out in, and what rpm should i rev to make the tires spin?
Pull into the burnout box, stop where the track official tells you to (usually at the end of the water line), pull up e-brake handle, put car in 2nd, rev up to 6000-7000rpm, drop the clutch, spin tires until smoke comes through vents... unless it's hot out, then go maybe 4 seconds, release ebrake, go to line.
Old Jun 28, 2007 | 11:33 PM
realis9's Avatar
Default Re: (Quik Chris)
to keep to the tires spinning just keep the rpm close to my rev limiter by pedaling the gas without bouncing of the rev limiter?
Old Jun 29, 2007 | 12:00 AM
a1320honda's Avatar
Im not tryin to get into a big debate, but burnouts on some street tires do make a difference. I have falken ziex's 205/50/15 and at 35psi and no burnout i was cutting 2.5-2.6 60ft's with massive wheel spin. Dropping the tire pressure to about 18 psi and a decent burnout and im doin consistent 1.94-1.95 60ft. My tires were workin better than my buddys with BFG drag radials.
Old Jun 29, 2007 | 12:14 AM
Redline130's Avatar
Default Re: (a1320honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">Im not tryin to get into a big debate, but burnouts on some street tires do make a difference. I have falken ziex's 205/50/15 and at 35psi and no burnout i was cutting 2.5-2.6 60ft's with massive wheel spin. Dropping the tire pressure to about 18 psi and a decent burnout and im doin consistent 1.94-1.95 60ft. My tires were workin better than my buddys with BFG drag radials.
I think dropping the tire pressure from 35psi to 18psi was a bigger factor in dropping your 60ft time than doing the burnout. 1.9's on street tires is very good nonetheless.
Old Jun 29, 2007 | 12:20 AM
a1320honda's Avatar
Default Re: (Redline130)
Ya ive made about 45 passes already trying every possible configuration. With em at 20-18 psi and no burnout i was doin 2.2-2.1 60's. I didnt cut a 1.9 till i did a burnout. The tires get so hot and soft and its just amazing how well they hook. During bracket racing just about everyone was coming over to check out my tires and especially the import guys. The fwd guys with drag radials were only doin 2.00's Im just sayin, even on street tires when done properly, the burnout box can be of good use.
Old Jun 29, 2007 | 12:22 AM
xxbulaxx's Avatar
As far as street tires go, it's not necessary to do a full burnout. Just a quick spin to dust them off. People make it out to be a huge deal though if you do a nice burnout. I did decent burnouts in my camaro on street tires(99 with a 6-speed) and always cut a 1.9x 60'. On the street, never do a burn out. You're tires heat up, and when you roll out they pick up all the grease and grime on the road. But at the track there's much less random grease and stuff, so the tires will still hook.
