fake ebay spoon mirrors
sorry no camera now, but they are these minus the fake carbon
http://cgi.ebay.com/ebaymotors...ZWDVW
it seems like the mirror is glued in or something if I were to take the bolts out it i would never get it back together
i really dont see why not? im not sure exactly waht you are trying to do though, just replace those 2 bolts here
or the actual glass? or the housing from the base thing
there is actually three bolts, and the nuts inside behind the glass will fall off if I take them out and won't be able to get them back together. by just looking at the pic you can't tell but the plastic is actually two pieces and those bolts hold them together
ok i think i get what ur saying, as soon as you back out the bolt, the nut will go away... and be hard to line back up
i dont think it would be just plain nut and bolt there should be some kind of nut holder, you know that stops the nut from spinning, holds it in place
if not, maybe put a drop of superglue to hold the nut in place to the innner housing
or if you can pop off the glass, that would work too but i think you could load up the nut in a open ended wrench or something and figure it out
hYbRiD EeEkAy
Jul 21, 2004 05:07 AM
