S2000 spoon calipers on type R?
Old Jun 27, 2007 | 05:52 PM
djpepsi's Avatar
Default S2000 spoon calipers on type R?
is there a way to make ap1 s2k spoon calipers fit a dc2 type r?
Old Jun 27, 2007 | 05:53 PM
Dave_B's Avatar
IS there a way? Technically, yes.
However, to make that work, I'm sure you'd need to fab up brackets. Are the rotors even the same size? I don't think it would be worth it IMO.
Old Jun 27, 2007 | 05:54 PM
itr1244's Avatar
Default Re: S2000 spoon calipers on type R? (djpepsi)
yes
nothing is impossible
Old Jun 27, 2007 | 06:06 PM
djpepsi's Avatar
yea i have a set so its prob be cheaper to make them work then buy dc2 ones for 1700$
i though i saw a post before that the spoon calipers are universal u take off the brackets and buy dc2 ones im not sure, if the rotors are bigger thats no prob i can put bigger ones like s2k ones.
Old Jun 27, 2007 | 06:12 PM
itr1244's Avatar
Default Re: (djpepsi)
do it up. make your own bracket if you have to. make it work. and show us how you do.
Old Jun 27, 2007 | 06:24 PM
Ferrell's Avatar
Default Re: (itr1244)
give them to me....i need some for the rear
Old Jun 27, 2007 | 06:52 PM
JjuuN R's Avatar
Default Re: (Ferrell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell &raquo;</TD></TR><TR><TD CLASS="quote">give them to me....i need some for the rear </TD></TR></TABLE>
Front and Rear, that'd be sick...
Old Jun 27, 2007 | 06:57 PM
Bradstard's Avatar
Sell them and buy the DC2's.
Old Jun 27, 2007 | 07:00 PM
itr1244's Avatar
Default Re: S2000 spoon calipers on type R? (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Sell them and buy the DC2's.</TD></TR></TABLE>
yeeah. why not eh? lol
Old Jun 27, 2007 | 07:23 PM
RStoR's Avatar
Default Re: S2000 spoon calipers on type R? (itr1244)
So many people are quick to dismiss things.
Mugen DC2 Active Gate Brakeset = OEM S2K Caliper
IF the Spoon S2K Monoblock uses the OEM mounting locations then it may bolt up to the DC2 knuckle.
Mugen evidently created a rotor to compensate for the S2K/Active caliper location so you may need to purchase those rotors to make them work. Mugen claims you have to have 16"+ wheels for clearance. Take offset into consideration too.
Just food for thought!
Old Jun 27, 2007 | 07:25 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: S2000 spoon calipers on type R? (RStoR)
pulling through in the clutch
Old Jun 27, 2007 | 07:29 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">So many people are quick to dismiss things.
Just food for thought! </TD></TR></TABLE>
Going on my R. ^^
Old Jun 27, 2007 | 07:30 PM
GO-FIGHT-KILL's Avatar
I'm going to call Honda/Advance Auto Parts/Vatozone, and get some prices on these tomorrow... It might be worth buying a set to see how/if they fit. And if not, I can always just return them.
I have 16" Circuit-10s, so clearence should not be a problem.
Old Jun 27, 2007 | 07:32 PM
94rs-turbo's Avatar
yeah I was just thinking about the hole mugen kit being s2k calipers
Old Jun 27, 2007 | 09:41 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: (94rs-turbo)
ask mikehonda, he has s2k spoon clapper setup.
Old Jun 27, 2007 | 10:11 PM
gsr-2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">yes
nothing is impossible</TD></TR></TABLE>
Let's see you fly
Old Jun 27, 2007 | 10:22 PM
slofu's Avatar
Default Re: S2000 spoon calipers on type R? (gsr-2nr)
check out an airport.
Old Jun 28, 2007 | 07:48 AM
clayton bigsby's Avatar
Default Re: S2000 spoon calipers on type R? (slofu)
S2k momoblocks
Old Jun 28, 2007 | 09:20 AM
Dave_B's Avatar
Since some are saying/showing it works... What does it take? Different brackets? Larger rotors?
Old Jun 28, 2007 | 09:59 AM
JjuuN R's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Since some are saying/showing it works... What does it take? Different brackets? Larger rotors?</TD></TR></TABLE> Both to say the least.
Old Jun 28, 2007 | 11:16 AM
nautica_t's Avatar
i was just thinking, wouldn't this be overall better than the dc2 spoon block?
i mean, bigger rotors at least and bigger pads, so better clamping force?
Old Jun 28, 2007 | 12:33 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djpepsi &raquo;</TD></TR><TR><TD CLASS="quote">cheaper to make them work then buy dc2 ones for 1700$
You should be able to find the DC2 model for less then that.
Old Jun 28, 2007 | 03:04 PM
Ferrell's Avatar
Default Re: (nautica_t)
Less flexing with the monoblocks...
Do the benefits outweigh the hassle?
On another note... apparently I have a set of active gates laying in the corner of my garage. $500 anyone?
Old Jun 28, 2007 | 05:55 PM
MooFX's Avatar
I'm using the Spoon monoblocks (S2K size Spoon calipers) on my car at the moment. You dont need to modify the brackets, it will bolt up directly to your hub, however, you will need to use the Spoon oversized (300mm) rotors, I tried using regular S2000 rotors, but you will need to either shave down your hub or the inside of the rotor since the inner of the stock s2k rotors are too small.
Justin
here's a pic with 16" wheels (you will not be able to run 15" wheels anymore with this brake setup)
Old Jun 28, 2007 | 06:47 PM
BrakeExpert's Avatar
Default Re: (MooFX)
In case you guys are curious, this can be made to fit civics/integras as well.
The Mugen calipers over the 11.8" rotor, just replace the caliper with the Spoon monoblock ones.
P.S. Anyone wants these calipers and/or rotors, PM me.
Modified by BrakeExpert at 12:29 AM 6/29/2007
