Few simple questions.
Old Jun 27, 2007 | 05:40 PM
BSeriesRescueteam's Avatar
Default Few simple questions.
Hi, I recently obtained a 1990 Hatch with the lunchbox D15B2. Now it's completely stock...except the header Anyways i have a few simple newbie questions to lay down.
Since the CRX has pretty much the same front end, putting on a hood from that car would be pretty much the same as putting a hood on from my model car? Or even a 4door or Wagon?
D15 axles, say i wanted to put a d15 axle from an EG in my ride, will it work? reason i ask that is because i can get them for free and my axles are wearing out.
Compression, ok so i did a compression test and it was 120, 150, 120, & 150 again. Shouldn't it be around 190 or 200?
EG Seats, will they fit?
My bad if these questions have been asked 1000 times, i'm new of course so i'm a dumbass.
-Jason
Old Jun 27, 2007 | 05:56 PM
91_Civic_Hatch's Avatar
Default Re: Few simple questions. (BSeriesRescueteam)
Ok, to answer some of your questions. You'll have to find a CRX hood or a hatch hood and a four door hood will NOT fit. Yes you can use the EG axles. Not sure on the compression thing. EG seats will need modification but will fit.
Use the red search icon in the top right corner next time. Some people get agrivated if you ask questions that are already in this forum. Just a heads up.
Old Jun 27, 2007 | 09:24 PM
lessonsinspeed's Avatar
Compression should range from 185 psi (new) to 135 psi (rebuild limit), with no more than a 28 psi difference. Since you have two cylinders under and are over the spread, I'd say a rebuild should be in the near future.
Mushvroom
Aug 10, 2005 08:49 AM
