Brake Fade
Old Jun 27, 2007 | 05:32 PM
xHARLEYGUYx's Avatar
Default Brake Fade
Have A 1994 Accord, brake pedal fades to floor, but not all the time. replaced frt and rear brakes,also replaced wheel cylinders. where do i go from here?
Old Jun 27, 2007 | 05:50 PM
The-Kid's Avatar
Default Re: Brake Fade (xHARLEYGUYx)
A member had the same problem. You might want to use the search button. I'll edit when I see it.
Old Jun 27, 2007 | 05:51 PM
The-Kid's Avatar
here ya go. https://honda-tech.com/zerothread?id=2025848 if you need more help reply bacl
Old Jun 28, 2007 | 10:47 AM
Default Re: Brake Fade (The-Kid)
thanks for the link,seems his fades all the time mine will feel fine and every once in a while fade to floor. strange but it happens,its my daughters car and when she told me about it i drove the car and it was fine, the next day i drove it again and brakes felt good for about 2 miles, came to stop and pedal went to floor, pumped them a few time and felt fine again?
Old Jun 28, 2007 | 12:21 PM
TOP END MS's Avatar
Id start with bleeding the brake lines. You might need a full bleed w. brand new fluide. Or check your lines for cracks/leaks.
Old Jun 28, 2007 | 04:15 PM
Default Re: (TOP END MS)
thank for the advice, will give it a try
trianglegreg
12
Dec 8, 2006 06:55 PM
VTECth1s
Jun 2, 2006 07:12 AM
nurvcom..
Feb 3, 2006 06:30 PM
MyYellowHonda
Jun 10, 2002 07:29 AM
dnt94civic
Jun 7, 2002 05:04 AM
