(Fuel) Kill Switch Woes
Well, I'm getting everything in order for my kill switch install.
Just to make sure everything is on the up-and-up..
1) This switch? http://www.radioshack.com/prod...62533
2) What gauge wire do I use? I've heard 14, 16, and 18? (Kill switch will be approx 2 feet away from spliced wire)
3) Should I use a relay? (Since it's only 2-feet away)
4) Any words of advice/tips or hints/anything of the sort before I get to cutting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">I used about 4 foot of wire when I did mine because of where I hid the bastard! I'm gonna post a good write up for you in a few mins so hang tight.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1794938
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek360 »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1794938</TD></TR></TABLE>
expletive that...That write up is way too over complex and kindof rediculous. The one I posted is way simpler and works...I've had mine installed for years with no problems what so ever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">Here you go......Awesome write up!!
http://www.teamdelsolwa.com/howto/fuelcutoff.htm</TD></TR></TABLE>
Will you link me to the wire you used? Thanks.
one good way to let everione know that ur car is being jacked is to connect ur horn to the ignition switch and a switch in between that way when someone start ur car and the switch is armed the the horn will go off without stoping until they disconnect the battery
just one layer of security
expletive that...That write up is way too over complex and kindof rediculous. The one I posted is way simpler and works...I've had mine installed for years with no problems what so ever.</TD></TR></TABLE>
http://causeforalarm.thecarthi....html
This has pics and works... too each his own doesn't make sense to be narrow minded.
Simple
13
Jan 10, 2004 07:57 AM
