Need Tires but don't know what size. Need Help!
Old Jun 27, 2007 | 03:41 PM
Da D0n's Avatar
Default Need Tires but don't know what size. Need Help!
Im driving a 97 4dr Honda Civic with Stock suspension. I got 17'in Rims and my current tire size is 205/40/17. Now I am in need of new tires and would also want a thicker look. Someone said that 215/45/17 is the best way to go for what Im looking for but doesn't know if it will Rub.
Just askin if anyone on this board know the answer and also I would like to need a pic of car with them size tires just to see. Thx
Old Jun 27, 2007 | 05:42 PM
old man neri's Avatar
Default Re: Need Tires but don't know what size. Need Help! (Da D0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FAQ &raquo;</TD></TR><TR><TD CLASS="quote">
What size tires should I get?
The proper size depends on your car, not just the wheels you are using.
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16
For an Integra or '97-00 Civic, the following sizes are usually best:
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16, 215/45-16
17" - 205/40/17
This is open for discussion and by no means what you have to get, but as a general rule you cannot go wrong with these sizes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da D0n &raquo;</TD></TR><TR><TD CLASS="quote">
Someone said that 215/45/17 is the best way to go for what Im looking for</TD></TR></TABLE>
That someone is an idiot.
I hope this helps and if you hve any questions or need help figuring out which make/model of tire suits your needs please do not hesitate to ask.
Cheers.
PS Can some please remind me what is the scripture for changing font in this damn thing.....
Old Jun 27, 2007 | 06:08 PM
Da D0n's Avatar
Default Re: Need Tires but don't know what size. Need Help! (old man neri)
So y isn't 215/45/17 a proper size for my model Civic? Will it rub the wall or something? it seems like it would but thats the only thing I'm worried about is rubbing.
btw I got a 1997 Honda Civic LX its a 4dr with stock suspension.
Old Jun 27, 2007 | 06:39 PM
Chance are it will rub, the speedo will be off, and your acceleration will suffer. Why do you want to get such a large tire anyways?
You also have to start considering what size rims are these tires going on.
Old Jun 27, 2007 | 07:01 PM
Da D0n's Avatar
Well there goin on 17's and the reason y I want bigger tires is cause the gap space between my tire and my fender is just not goin with the look. I got a body kit and I dont wanna lower my car so i'd rather just get thicker tires. The 205/40/17 is just too thin and doesnt go with it. But anyway do u know from experience of this size tire into a Honda Civic 4dr? just wanna know...
Old Jun 28, 2007 | 06:46 AM
nsxtasy's Avatar
H-T Order of Merit
old man neri is giving you good advice. Don't create problems for yourself by using the wrong tire size. Stick with the proper tire size for your car. With 17" wheels on a '97 Civic, that's 205/40-17.
If you don't like the way it looks and you want the look of bigger tires, then trade your car in for a different car, one that uses bigger tires, like a newer Civic. For example, 215/45-17 is a good size for a 2001 or later Civic. Maybe that's what your idiot "someone" was thinking of when he gave you that bad advice.
Old Jun 28, 2007 | 09:52 PM
Da D0n's Avatar
Default Re: Need Tires but don't know what size. Need Help! (nsxtasy)
I guess 215/45/17 wont fit correctly but I went to a tire shop and ask one of the guys who deals with tires what would fit best besides 205/40/17 and he said 205/45/17 would work because all I need is the wall height of the tire if thats what I wanted. I hope he's right but Im just double checking if you guys have any sugesstions. thx
Old Jun 29, 2007 | 05:34 AM
nsxtasy's Avatar
H-T Order of Merit
205/45-17 is too big also.
You need to get tires whose outer diameter is the same as stock, to avoid the problems that old man neri mentioned. That size is 205/40-17.
Stick with 205/40-17.
patrickstar
Mar 4, 2009 03:05 AM
BoboyRS
Feb 16, 2009 11:25 AM
c-r-x
Mar 19, 2008 01:48 PM
EGII
May 1, 2007 04:13 PM
platinumx6
Jan 4, 2007 07:02 AM
