Question about some parts?
Old Jun 27, 2007 | 02:35 PM
Jacen's Avatar
Default Question about some parts (Timing belt & water pump)?
getting ready to do the timing belt and water pump, question when I was buying the parts I notice another belt (#11) do I also need to change that belt as well?
Old Jun 27, 2007 | 02:40 PM
yOnKiNaToR's Avatar
Default Re: Question about some parts (Timing belt & water pump)? (Jacen)
that's the balancer shaft belt. i would change it while you're there along with the balancer shaft seals.
also if you are running autotensioner now is the time to convert to manual.
all this is covered in archived posts if you search.
Old Jun 27, 2007 | 06:44 PM
BrockNB's Avatar
you can just pull that belt too I believe.
sirr6
Dec 29, 2013 05:38 PM
D21X
Aug 21, 2006 04:54 PM
05member y0
Nov 16, 2005 09:36 AM
Kashi
Mar 14, 2005 07:01 AM
