Which brake lines for 92 EG w 99-00 Si brakes?
Old Jun 27, 2007 | 02:12 PM
blivic's Avatar
Default Which brake lines for 92 EG w 99-00 Si brakes?
I'm swapping 99-00 Civic Si front brake setup on my 92 Civic Si and was planning on adding in some stainless steel brake lines to the mix.
Do I need to buy 99-00 Si brake lines or do I just get the 92 Civic Si brake lines??
Thanks for your help!!
Old Jun 27, 2007 | 09:39 PM
blivic's Avatar
Default Re: Which brake lines for 92 EG w 99-00 Si brakes? (blivic)
bump
Old Jun 28, 2007 | 10:25 PM
WhiteNess's Avatar
92 eg front lines(frong 99-00 lines are too short for the EG)....and 99-00 si rear lines ( they are longer than the eg lines and will reach the calipers)
Now since you have an Eg si you already have rear disc brakes, so i'm not 100% sure if your stock rear lines will reach the new 99-00 calipers.
Old Jun 29, 2007 | 02:31 AM
blivic's Avatar
Default Re: Which brake lines for 92 EG w 99-00 Si brakes? (WhiteNess)
so the 99-00 lines are too short? maybe i just use 92-95 brake lines?
so for sure 92-95 rear brake lines will work since i have the stock discs in the back.
can anyone confirm that the eg front brake lines will work with 99-00 brakes?
Old Jun 29, 2007 | 09:12 AM
WhiteNess's Avatar
The 92-95 eg front lines will fit the 99-00 si brakes......when I tried using the lines from the 00 si I got my brakes from they were too short.
It has to do with the position of the hard brake line. On eg's and teg's it's on one side of the wheel assymbly....and on eks its on the other.
elnoyl
May 6, 2009 05:38 PM
k624ash
Sep 10, 2006 01:40 PM
