99 Accord EXV6 -- Electrics
Old Jun 27, 2007 | 11:59 AM
Oahubound's Avatar
Default 99 Accord EXV6 -- Electrics
Have a 99 EXV6 that just broke 100K, well maintained. Upon starting the car today, the following indicator lamps stayed on: maintenance, brake, charging system, and all doors and trunk "open lights". The engine seems to run fine and the lamps stayed lit upon re-starting the engine. Any ideas?
Old Jun 27, 2007 | 03:48 PM
hondadude's Avatar
Default Re: 99 Accord EXV6 -- Electrics (Oahubound)
Get your radio code in hand ...then unhook the battery negative cable for a minute.
Hook the battery back up and try again. Resets the multiplex control unit.
Old Jun 28, 2007 | 08:34 AM
Oahubound's Avatar
Default Re: 99 Accord EXV6 -- Electrics (hondadude)
Hondadude --- thanks for your suggestion. Going to try that today. By disconnecting the negative cable, will I run into any problem with the alarm systems?
Old Jun 30, 2007 | 05:56 PM
zeroice's Avatar
its your alternator... better get it changed before you get stuck somewhere...
Old Jun 30, 2007 | 07:04 PM
YeuEmMaiMai's Avatar
forget that
turn everthing off and set the intermittent wiper ring to the moddle position and turn the car on, (do not start it) wait 10 sec, and turn the car off. that resets it without having to disconnect the battery.
If you turn your car on and you got the door ajar and break and alt lights, time to replace that POS delphi alt. lights may go off as you rev the motor.
like zeroice said, replace it asap before you are stuck and need a new battery becuase your alt toasted it.
Old Jun 30, 2007 | 07:22 PM
361 accord's Avatar
Default Re: 99 Accord EXV6 -- Electrics (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">
turn everthing off and set the intermittent wiper ring to the moddle position and turn the car on, (do not start it) wait 10 sec, and turn the car off. that resets it without having to disconnect the battery.</TD></TR></TABLE>
tiiiiiiight, would there be ANY reason to do that if my accord is runnin fine?
Lpairol1992
Sep 27, 2017 10:48 AM
hondalion
Jun 25, 2013 05:25 PM
elposton
Dec 16, 2011 10:29 AM
Mychal71
Oct 10, 2008 03:38 PM
Heat
Jul 29, 2004 12:39 PM
