Monster, getting out of the scene, for sale thread. HKS, Spearco, Corbeau, STR, Schroth, Autronic,
Old Jun 27, 2007 | 11:45 AM
jdmb16acivic's Avatar
Default Monster, getting out of the scene, for sale thread. HKS, Spearco, Corbeau, STR, Schroth, Autronic,
Here is a list of the majority of the parts I have for sale with prices. Prices are negotiable but please no lowballing.
~HKS SSQV BOV-$100
~HKS Type 0 turbotimer-$75
~Spearco FMIC (roughly 20?by8by3) w/angled endcaps-$500
~STR polished B-series fuel rail-$50
~M&W Pro 10 ignition box-$400
~Autronic SMC engine management-$1200
~Corbeau ForzaII black race seats-$400
~Corbeau Honda sliders-$100
~Schroth black 4pt harness’-$200
~Autometer Sport Comp. 2” gauges:
Electric coolant temp-$75
Electric oil pressure-$75
Electric oil temp-$30
Air/Fuel-$40
Boost-$50
EGT-$100
~Autometer Pro Comp. 3 3/4” gauges:
Tach (10,000rpm)-$100
Speedo (160mph)-$100
~Custom fiberglass gauge pods for 88-91 Civics (triple pod for upper center air vents, triple pod in place of ashtray, single pod in gauge cluster surround, gauge cluster itself to hold (2) 3 3/4 gauges, shiftlight and turbo timer)
~Autometer dual A-pillar pod for 99-91 Civic
~Moroso battery box-$75
~MSD cap, coil w/bracket, and black 8mm wires for B-series-$100
~88-00 Civic adjustable ball short shifter-$50
~Type R style shift ****-$15
~carbon fiber/polished e-brake handle-$10
~(2)Falken Azenis 205/50/15’s w/ good tread-$75
~(2)G60 Sebring wheels w/Toyo Proxes FZ4’s w/ good tread-$100
~Place Racing front crossmember for 88-91 civics-$75
~Place Racing B-series shift linkage for 88-91 civics-$75
~Place Racing engine mounts for B-series into 88-91 civics-$75
~Turbonetics manual boost controller$50
~Turbonetics silicone couplings:
(2) 2” 90’s-$40 each
2” coupling-$20
2”-3” adapter coupling-$30
~Set of Scion TC blackies-$50
~B16A swap w/ y1 cable tranny...Motor was rebuilt about 10k miles ago with:
Hasting piston rings, Race Engineering blockguard, OEM Honda
valve seals, head gasket, timing belt, rod bearings, head studs,
OE oil pan gasket,(oil pan has been tapped for oil return but can
be plugged with -8AN plug) OE valve cover gasket (valve cover
has nipple welded on for Evac. setup and is powdercoated black),
comes with STR cam gears and cam seal, Unorthodox Racing
single belt underdriven race crank pulley and lightweight alt.
pulley. Has rebuilt starter and alternator from about 10k ago as
well. DOES NOT INCLUDE: fuel rail, fuel injectors, distributor &
some misc. sensors. I will throw in another set of b16a rods and
pistons, an extra oil and water pump, black carbon canister,
some misc. sensors I have laying around as well as some other
parts that you could use but I no longer want or need laying
around. $2000
~Energy Suspension Master Kit for 88-91 civics (missing front LCA kit, pt#16.3103. front shock bushing set, pt #16.8102. and shifter bushing set. $50
~Powdercoated black IC piping-20
~Powdercoated black B-series cable tranny casing-$100
~YS1 cable B-series tranny-$400
~ZC style carbon fiber hood for 88-91 civics w/ Sparco hoodpins. Has a lot of cracks in clear coat ONLY. Has no place for latching mechanism so you must use hoodpins. Webbing on underneath was cut away for clearance for my turbo. Great lightweight hood but unless you don’t mind the crack which I didn’t, I would suggest getting it painted and having a nice light hood for cheap-$75
~Bare b16a2block except for crank-$50
~b16a2 oil pump with less than 12k on it-$25
~b16a2 water pump with less than 12k on it-$25
~90-93 GSR steering wheel (no airbag)-$25
~4 door GSR floormats-$50
~Custom stock front bumper from 90-91 civic hatch (plastic welded bottom of another bumper on to lower the front while retaining stock appearance as well as plastic welded pieces on to the sides of openings to just allow FMIC to show. (Will sell bumper, FMIC, frame brace/FMIC protection bar, and modified bumper bracket as a package but will only work on 88-91 civics) Stock or aftermarket lip can still be installed on modified bumper
~Canadian and US style door panels for 88-91 civics
~I’m parting out an entire 90 civic hatch so I have a ton of stock random parts as well....ie. headlights, doors, glass, dash, wiper motors, seatbelts yada yada yada.
***I think my suspension is spoken for but I will put this on here in case somebody else is interested and my friend falls through. This will be sold as a complete unit ***
~Tokico Illumina 5way adjustable shocks, Skunk2 coilovers, Integra brake upgrade up front w/ slotted rotors and green stuff pads, Energy suspension LCA bushings, front shock bushings, sway bar bushings, new tie rod ends on steering rack, all new front ball joints, rear drums have been completely rebuilt and it has an adjustable camber kit. $900
Old Jun 27, 2007 | 11:44 PM
Default Re: Monster, getting out of the scene, for sale thread. HKS, Spearco, Corbeau, STR, Schroth, Autron
TTT
Old Jul 1, 2007 | 09:46 AM
TTT
Old Jul 2, 2007 | 05:32 PM
IT'S ME DAVID's Avatar
NooB
Old Jul 10, 2007 | 04:56 PM
95accordex1's Avatar
can i get pics on the str fuel rail?
Old Jul 10, 2007 | 05:15 PM
Smokinsax's Avatar
The Boot
pm'd
Old Aug 25, 2007 | 09:58 PM
chunkybs's Avatar
Default Re: (Smokinsax)
willing to sell just 1 seat?
GSRl2ider 23
Jul 16, 2007 09:14 AM
Rizza
Aug 5, 2002 12:57 AM
